Ir para o conteúdo principal
MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement
O que você precisa
  1. MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement, Lower Case: passo 1, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Magnetic Project Mat
    $19.95
    Comprar
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
    If don’t have one of those neat project mats, then you can use small pieces of flattened blu-tack to hold the screws. If you arrange them in the shape of your mac book cover, and put the screws down methodically, you can get a one-to-one mapping of the screws to the correct screw holes.
    Toby Thurston - Responder
    Or you can use an ice tray where you put the screws and the parts in separate bays in the same order as they come in the instructions.
    timofej.se -
    This is great! I used a small magnetic white board, and wrote on it to identify the parts as I went. This whole process, from the fast shipment to the great instructions to the complete, high quality, tool kit has been great. I’m typing this comment on my resurrected laptop. Thank you! Sue
    Susan Greer - Responder
    It would be a good idea if people recorded in the comments which screws go where so that, if someone lost their screw positions, they could recover them from the comments.
    Raymond Shpeley - Responder
  2. MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: passo 2, imagem 1 %32
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  3. MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: passo 3, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: passo 3, imagem 2 %32 MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: passo 3, imagem 3 %32
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case at the center, with two plastic clips.
  4. MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement, Battery Connector: passo 4, imagem 1 %32
    • Remove the plastic cover adhered to the battery contact board.
    The replacement cover doesn't seem to have the formed pads attached. I re-installed the original.
    Adrien - Responder
  5. MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: passo 5, imagem 1 %32
    • Remove the following screws securing the battery connector board to the logic board:
    • Two 2.8 mm T6 Torx screws
    • One 7.0 mm T6 Torx shouldered screw
  6. MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: passo 6, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: passo 6, imagem 2 %32
    • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
    Is adhered to screw beneath, so lift firmly and slowly.
    Andrew - Responder
    when doing this with metal tweezers as instructed in the video, it was difficult to get off and apparently while i was trying to do it, the tweezers went too far under and i believe made contact with the screw underneath? there was a zzz noise, an orange flicker and a little stream of smoke that came out. i freaked out and put everything back together to see if the laptop even still worked, it turned on and everything but died right away (i drained it before doing the repair anyway, so i was surprised it turned on at all).
    i finished the battery repair and did several other things while in there. i have charged it all the way as recommended and will use it later on to see how everything is, im hoping that it’s a okay, but could someone explain to me what happened and the possible consequences?
    Kait D - Responder
  7. MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: passo 7, imagem 1 %32
    • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
    When reinstalling, be careful that the board lines up correctly and is completely seated in order for this screw to thread properly.
    Adrien - Responder
  8. MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: passo 8, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: passo 8, imagem 2 %32
    • Carefully lift the battery connector board up off the logic board.
    • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Do not fold the board completely over, or crease the cables, as this may damage the battery.
  9. MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement, Battery Contact Board: passo 9, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement, Battery Contact Board: passo 9, imagem 2 %32
    • Grasp the Interposer with tweezers.
    • An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
    • Lift the Interposer off the logic board and remove it.
    • Removing this board will ensure that the battery remains disconnected throughout your repair, preventing your computer from accidentally powering on. It's also a good idea to take it out so it doesn't fall out unexpectedly.
    How can I remove interposer I m not able to remove it
    Raunak - Responder
    you must lift it absolutely vertically, or it fouls against the locator pin in the corner- you can easily get the impression that it won’t come over the end of this pin- almost like it’s rivetted in. it isn’t. get a good grip on it with the tweezers in the centre hole & one of the sides, & lift it STRAIGHT up.
    duncan rmi -
    I would recommend to use plastic tweezers in order to reduce risk of damage.
    Martin Sippel - Responder
    Second that. If you have thin heat shrink tubing, form some over the tweezer tips. If the tubing is thin and small enough in diameter you’ll see the serrations of the tweezer tips.
    Raymond Shpeley -
    wat is the model this SSD
    thierry.wilow - Responder
  10. MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement, I/O Board Data Cable: passo 10, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement, I/O Board Data Cable: passo 10, imagem 2 %32
    • Use the flat end of a spudger to pry the right side of the I/O board data cable connector up off its socket on the I/O board.
    • When prying the I/O board data cable connector from its socket, make sure to pry the connector itself and not the socket. Prying the socket may cause irreversible damage to the I/O board.
    I keep my fingernails fairly long, very handy for many computer repair jobs. This gives me 10 spudgers over which I have very fine muscular control. It is far easier to pop some of these tiny delicate MacBook parts loose with my nails.
    Ben Myers - Responder
    Skip this step. For an easier, lower-risk repair, go straight to step 15 and just fold the speaker out of the way.
    .A. - Responder
  11. MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: passo 11, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: passo 11, imagem 2 %32
    • Wedge the flat end of a spudger beneath the left side of the I/O board data cable connector.
    • Gently twist the spudger to disconnect the I/O board data cable connector from its socket on the logic board.
    I also skipped this step as this data cable is not compromising the exchange of battery and less interaction with connectors is less risk of damage..
    Diesen Schritt habe ich ebenfalls weggelassen, da das Datenkabel den Austausch der Batterie nicht behindert und weniger Manipulationen an Steckverbindern bedeutet ein geringeres Risiko für Beschädigungen
  12. MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: passo 12, imagem 1 %32
    • Lift and remove the I/O board data cable from the MacBook Pro.
    This step is useless. Could be skipped
    Pierre S. - Responder
  13. MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement, Right Speaker: passo 13, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement, Right Speaker: passo 13, imagem 2 %32 MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement, Right Speaker: passo 13, imagem 3 %32
    • Use the flat end of a spudger to pry the SSD cable connector up from its socket on the logic board.
    • Move the SSD cable connector out of the way.
    As per my comment on step 10, this is also not required. When you remove the SSD in step 22, you can just fold it over out of the way.
    .A. - Responder
    This step is easy enough that I’d just remove it to be out of the way. I 100% agree with your other comments though. While you’re here, might as well do step 21 and remove the drive, just takes a sec.
    maccentric -
    I also strongly recommend not to unmount the speaker plugs, just flip them out of the way, same as with the SSD drive. Makes it much less complicated and less risky. It worked perfect for me.
    Ich empfehle ebenfalls, die Platinenstecker der Lautsprecher nicht zu lösen sondern die Lautsprecher einfach, so wie das SSD-Laufwerk, einfach aus dem Weg zu legen. Das macht die Sache weniger kompliziert und weniger risikoreich. Es hat bei mir super funktioniert!
  14. MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: passo 14, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: passo 14, imagem 2 %32
    • Wedge the pointed end of a spudger beneath the right speaker cable connector.
    • Gently pry the right speaker cable connector up off from its socket on the logic board.
    • Be sure you are prying up on the connector, not the socket itself.
    When reassembling be careful that the right speaker wire is flush against the battery. At first, it was slightly touching the airport/bluetooth board causing wifi and bluetooth to not work after restarting.
    Stu - Responder
  15. MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: passo 15, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: passo 15, imagem 2 %32
    • Use a T5 Torx driver to remove the following screws securing the right speaker to the upper case:
    • One black 6.8 mm screw
    • One silver 6.3 mm screw
    • One black 4.9 mm screw
    • The silver screw (in the corner) may be covered with a foam pad. If so, use your tweezers to peel it up and remove it.
    If you manage to misplace any screws, particularly one of the speaker retaining screws, look under the speakers - they are magnetic and great at hiding missing screws :)
    Peter Newman - Responder
  16. MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: passo 16, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Right Speaker Replacement: passo 16, imagem 2 %32
    • Lift and remove the right speaker out of the upper case.
    • If necessary, de-route the right speaker cable from its channel in the upper case.
    For those who don’t realize it, the speakers you are removing really are the plastic corner pieces that look like they’re just there to fill the space.
    S Cockerille - Responder
Conclusão
33 outras pessoas executaram este guia.
5 comentários
Thanks for the steps, it worked. But now I am getting Wi-Fi- No hardware installed and Bluetooth Not available error
Divakar Jayaraman - Responder
it worked but the cam is not working now :(
I was able to fix the right speaker using the solvent used to remove the battery provided by iFixit.
Peter-Paul van Beekum - Responder
Thank you very much for the walkthrough. No problems to follow at all. Everything worked as a charm.
timofej.se - Responder
Thanks very much for the walkthrough. No problems at all. Everything working fine afterwards.
Vaughan Butler - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 115
Duração total: 23,020
