Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Prereq for upper case, battery removed.
O que você precisa
Use the tip of a spudger to push the edges of the I/O board connector straight out of its socket on the logic board.
Carefully lift the logic board assembly from its left side and work it out of the upper case, minding any cables and the I/O ports that may get caught during removal.
Pull the right I/O port side of the logic board away from the side of the upper case and remove the logic board assembly.
