Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Use the flat end of a spudger to pry and disconnect the three antenna cable connectors from the AirPort board.
Connect the long-sleeved cable to the center socket.
The short-sleeved cable connects next to the screw.
The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
Remove the following two screws securing the I/O board to the upper case:
One 3.53 mm T5 Torx screw
One 4.89 mm T8 Torx standoff screw
Carefully pull and remove the I/O board away from its recess in the upper case.
