Introdução
Use this guide to replace the AirPort board.
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Remove the single 2.7 mm T5 Torx screw securing the AirPort board to the I/O board.
Use the flat end of a spudger to pry and disconnect the three antenna cable connectors from the AirPort board.
Connect the long-sleeved cable to the center socket.
The short-sleeved cable connects next to the screw.
The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
13 outras pessoas concluíram este guia.
5 comentários
Hello
Is this showing how to upgrade a MBP min2012 from non-retina to retina display?
Hi, I've seen this Airport board teardown and the Early 2015 one. I think that Airport board is the same and I would like to replace my board with the Early 2015 one. Can you tell me if is it possible? Can be driver issues? Mac OS version issues? Thank you
Thanks for this. I just used this to upgrade my Late 2012 to AC.
Hi Gary, so are you saying that you found a new Airport card that is AC for this “N” stock version ? If so, could you share a link to it?
Thanks!
Michael
Michael -
Hi, I replaced the card. Even though I was not able to disconnect the battery, because some of the screws there are not screwable anymore after replacing the battery a couple of years ago…
But it worked. Wifi is working fine. But my main problem was that the Bluetooth did not work. The Computer did not even recognize that there is bluetooth hardware anymore, it says Bluetooth: not available.
Unfortunately this problems stays with the new card.
Might there be a falty wiring somewhere else? does anybody has another suggestion to try?
Thanks.
