Ir para o conteúdo principal
MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement
O que você precisa
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  1. MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement: passo 2, imagem 1 %32
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  2. MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement: passo 3, imagem 1 %32 MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement: passo 3, imagem 2 %32
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  3. MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement, Battery Connector: passo 4, imagem 1 %32
    • If necessary, remove the plastic cover adhered to the battery contact board.
  4. MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement: passo 5, imagem 1 %32 MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement: passo 5, imagem 2 %32
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  5. MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement: passo 6, imagem 1 %32
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  6. MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement, MagSafe DC-In Board: passo 7, imagem 1 %32 MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement, MagSafe DC-In Board: passo 7, imagem 2 %32 MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement, MagSafe DC-In Board: passo 7, imagem 3 %32
    • Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board.
    • Pull in the direction of the cable, parallel to the logic board. Do not pull up.
  7. MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement: passo 8, imagem 1 %32 MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement: passo 8, imagem 2 %32
    • Pull the DC-In board connector straight out of its socket on the logic board.
  8. MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement: passo 9, imagem 1 %32
    • Remove the two 3.5 mm T5 Torx screws securing the MagSafe DC-In board to the upper case.
    • You may need to gently push the display cable out of the way to expose the screws.
  9. MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement: passo 10, imagem 1 %32 MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement: passo 10, imagem 2 %32 MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement: passo 10, imagem 3 %32
    • Use the MagSafe DC-In board cable to pull the board out and up from the upper case to remove it.
Conclusão
39 outras pessoas executaram este guia.
Andrew Optimus Goldheart
Membro desde: 10/17/09
493.376 Reputação
407 Guias de autoria
Equipe
iFixit Membro de iFixit
Community
139 Membros
16.882 Guias de autoria
4 comentários
Since a few days the area around the MagSafe-DC is getting quite hot, regardless of wether the Mac is running or idle. Does this have anything to do with the MagSafe-DC? Any recommendations?
Nils Fenske - Responder
Hi Folks,
Just went through these very clear steps on replacing the DC-in board after the pins on my old one were burned.
First off, success…ish with the replacement and the mac is back to charging again in high spirits. However, I am now notified of a “service battery" beneath the charge drop down menu. In checking the system information, the battery is at a cycle count of 824.
I am not quite sure what to do at this point and appreciate any tips.
Best,
random guy on the internet
Joseph Van Linn - Responder
Replace the battery.
maccentric -
Hi there !
My mac won't charge the freshly replaced new battery... event tho it's running fine and recognized by the system...
I've been Changing the battery / Reseting SMC & NVRAM / Clean install on Monterey...
It still tells me :
Power source : power adapter
Battery is not charging
Do you think replacing the DC-in board would help ?
Thanks for your advices !
pulla - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 71
Últimos 30 dias: 383
Duração total: 24,248
