Ir para o conteúdo principal
MacBook Pro 13" Retina Display Early 2015 Lower Case Replacement
O que você precisa
  1. MacBook Pro 13" Retina Display Early 2015 Lower Case Replacement, Lower Case: passo 1, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Magnetic Project Mat
    $19.95
    Comprar
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Early 2015 Lower Case Replacement: passo 2, imagem 1 %32
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  3. MacBook Pro 13" Retina Display Early 2015 Lower Case Replacement: passo 3, imagem 1 %32 MacBook Pro 13" Retina Display Early 2015 Lower Case Replacement: passo 3, imagem 2 %32
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
Conclusão
27 outras pessoas executaram este guia.
Andrew Optimus Goldheart
Membro desde: 10/17/09
503.000 Reputação
Autoria de 407 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 17.198 guias
5 comentários
Nice………………..!
Fred Starbuck - Responder
The bottom left-middle screw on my case is jammed and won’t come out—the more I try, the more I’m stripping it. Every other screw has been removed successfully, several times, with no problems. I wonder if I put in the wrong screw from somewhere else? Any ideas for removing it?
Jordan - Responder
do i get a laptop cover for mac book pro retina a 1502 model
naga usha - Responder
do i get a macbook pro retina A 1502 MODEL laptop cover (hard or soft shell)
I’m trying to install my lower case back but it’s refusing to clip back in. Any way I can fix it?
Jorge Ramirez-Centeno - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 91
Últimos 30 dias: 342
Duração total: 50,794
