Introdução
Use this guide to replace the solid state drive tray.
O que você precisa
Ferramenta utilizada neste passo:Magnetic Project Mat$19.95
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Ferramenta utilizada neste passo:Tweezers$4.99
Grasp the Interposer with tweezers.
Lift the Interposer off the logic board and remove it.
Use the flat end of a spudger to pry the SSD cable connector up from its socket on the logic board.
4 outras pessoas executaram este guia.
