Ir para o conteúdo principal
MacBook Pro 13" Four Thunderbolt Ports 2020 Lower Case Replacement
O que você precisa
  1. MacBook Pro 13" Four Thunderbolt Ports 2020 Lower Case Replacement, Remove the pentalobe screws: passo 1, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Magnetic Project Mat
    $19.95
    Comprar
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove the six screws securing the lower case:
    • Two 6.7 mm screws
    • Four 3.4 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Four Thunderbolt Ports 2020 Lower Case Replacement, Open a gap using a suction cup: passo 2, imagem 1 %32 MacBook Pro 13" Four Thunderbolt Ports 2020 Lower Case Replacement, Open a gap using a suction cup: passo 2, imagem 2 %32
    • Apply a suction handle to the lower case near the front-center area of the MacBook Pro.
    • Lift the suction handle to create a slight gap between the lower case and the chassis.
  3. MacBook Pro 13" Four Thunderbolt Ports 2020 Lower Case Replacement, Separate the clips: passo 3, imagem 1 %32 MacBook Pro 13" Four Thunderbolt Ports 2020 Lower Case Replacement, Separate the clips: passo 3, imagem 2 %32 MacBook Pro 13" Four Thunderbolt Ports 2020 Lower Case Replacement, Separate the clips: passo 3, imagem 3 %32
    • Insert one corner of an opening pick into the space between the lower case and the chassis.
    • Slide the opening pick around the nearest corner and halfway up the side of the case.
    • This releases the first of the hidden clips securing the lower case to the chassis. You should feel and hear the clip pop free.
  4. MacBook Pro 13" Four Thunderbolt Ports 2020 Lower Case Replacement: passo 4, imagem 1 %32 MacBook Pro 13" Four Thunderbolt Ports 2020 Lower Case Replacement: passo 4, imagem 2 %32 MacBook Pro 13" Four Thunderbolt Ports 2020 Lower Case Replacement: passo 4, imagem 3 %32
    • Repeat the previous step on the opposite side, sliding your opening pick under the lower case and up the side to pop the second clip free.
  5. MacBook Pro 13" Four Thunderbolt Ports 2020 Lower Case Replacement: passo 5, imagem 1 %32 MacBook Pro 13" Four Thunderbolt Ports 2020 Lower Case Replacement: passo 5, imagem 2 %32 MacBook Pro 13" Four Thunderbolt Ports 2020 Lower Case Replacement: passo 5, imagem 3 %32
    • Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
    • Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
    • Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
  6. MacBook Pro 13" Four Thunderbolt Ports 2020 Lower Case Replacement: passo 6, imagem 1 %32 MacBook Pro 13" Four Thunderbolt Ports 2020 Lower Case Replacement: passo 6, imagem 2 %32 MacBook Pro 13" Four Thunderbolt Ports 2020 Lower Case Replacement: passo 6, imagem 3 %32
    • Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
    • Pull first at one corner, then the other.
    • Pull to the side—not up.
    • This can require a lot of force.
  7. MacBook Pro 13" Four Thunderbolt Ports 2020 Lower Case Replacement, Remove the lower case: passo 7, imagem 1 %32 MacBook Pro 13" Four Thunderbolt Ports 2020 Lower Case Replacement, Remove the lower case: passo 7, imagem 2 %32 MacBook Pro 13" Four Thunderbolt Ports 2020 Lower Case Replacement, Remove the lower case: passo 7, imagem 3 %32
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
    • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
3 outras pessoas executaram este guia.
Carsten Frauenheim
Membro desde: 03/10/20
110.927 Reputação
Autoria de 338 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 16.573 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 16
Últimos 7 dias: 106
Últimos 30 dias: 352
Duração total: 10,054
