Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
The logic board is the main board inside the MacBook Core Duo and includes the processors, I/O ports, and RAM sockets.
O que você precisa
Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
Remove the following 3 screws:
One 11 mm Phillips #00 in the middle of the case.
Two 14.5 mm Phillips #00.
Starting near the display and working around to the front of the computer, pry up on the upper case. It is held with clips on the right above the optical drive. These will release with some firm lifting pressure.
Be careful when prying up the upper case. It's very easy to slice open a fingertip and thus provide the blood sacrifice the Mac gods sometimes require of those who insist on doing their own repairs.
Turn the logic board over.
Peel the PRAM battery up from its location on the logic board, removing tape as necessary.
79 outras pessoas executaram este guia.
2 comentários
is it possible to swap macbook 1,1 logic board (32bit) to macbook 4,1 (64bit) logic board? both model numbers are A1181.
I have black macbook 1,1 eating dust in the closet, but I would like to revive it to use it as an interior/music play machine.
Unfortunately, as my black macbook 1,1 has only 32bit CPU, it won’t upgrade above Snow Leopard.
I’d like to at least be able to upgrade where iTunes with Apple music is enabled, which probably is iTunes 12.
Thank you
So…. Damaged one of the temperature connections. But Got the pram out. How can I check if its working. First time I've stripped one down. The instructions were top class
