Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the small piece of foam tape stuck down above each of the bezel covers, at the lower left and right corners.
Use a spudger to slide the left bezel cover towards the LCD panel.
Lift the left bezel cover off the display assembly.
Use a spudger to slide the right bezel cover toward the LCD panel.
Lift the right bezel cover off the display assembly.
Lift the inverter out of the display slightly and disconnect the backlight cable from its right side.
Place the inverter back down in its recess.
Remove the single 3.2 mm Phillips screw securing the display data cable to the right clutch hinge.
Move the display data cable out from under the mounting arm of the right clutch hinge.
Remove the twelve 4.2 mm Phillips screws securing the LCD assembly to the rear display bezel.
Raise the bottom edge of the LCD assembly slightly, then slide it down slightly to free its upper edge from a slight overhang in the rear display bezel.
Lift it out of the rear display bezel, minding any cables that may get caught.
