Introdução
If you've got a coin, you can replace the battery in your MacBook Core Duo.
O que você precisa
Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
105 outras pessoas executaram este guia.
2 comentários
Hmmm My MacBook Core 2 Duo does not have a coin slot on back
Easy, but remember to replace with a battery from a reputable source and check the temperature when charging.
