Ir para o conteúdo principal
MacBook Core 2 Duo RAM cover replacement
O que você precisa
    1. MacBook Core 2 Duo RAM cover replacement, RAM cover: passo 1, imagem 1 %32
      • Please remove the three Phillips screws equally spaced on the partition of the battery on the back side of the main unit.
      • Since the screw is fixed to the metal memory cover, there is no worry of losing it.
      • (Translator's Comment) Although I am unable to turn Phillips (Phillips) screws in accordance with the JIS standards sold in Japan, since it does not mean that the shapes are perfectly matched, There is a possibility that it may not be possible to reassemble in the worst case because it is scraped.
      • Drivers for Phillips screws are sold with the notation PHxxx or PH # xxx if going to a home center etc. (x is a number, it is like 000, 00, 0, 1, 2 ... from the smallest tip order). Or you can also purchase it at the iFixit store because it is sold.
      Pergunte ao FixBot
      Comentar
    2. MacBook Core 2 Duo RAM cover replacement: passo 2, imagem 1 %32
      • Pull the L-shaped RAM cover towards you and remove it from the laptop.
      Pergunte ao FixBot
      Comentar
Conclusão
To reassemble your device, follow these steps in reverse order.
3 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
jp en
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Uhucream
Membro desde: 10/04/15
827 Reputação
Autoria de 2 guias
Equipe
Japanese Translators Membro de Japanese Translators
Community
6 Membros
Autoria de 19 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 64
Ao todo: 2,049
