Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
No power to the laptop? Replace the MagSafe board.
O que você precisa
Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
Unscrew the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
Remove the following 3 screws:
One 11 mm Phillips#00 in the middle of the lower case. (Head: 5mm dia. x .75mm thick)
Two 14.5 mm Phillips #00 (Head: 5mm dia. x .75mm thick)
Remove the left 3 mm and right 8 mm (right screw is unnecessary to remove on some models)
One 3.25mm Phillips #000 (Head: 4mm dia. x .5mm thick)
One 8.5mm Phillips #000 (Head: 4mm dia. x .75mm thick
136 outras pessoas executaram este guia.
4 comentários
Since the use of magnetic tipped drivers is probably NOT recommended, I'd keep some partially dried rubber cement or similar (snotty consistency) around to stick screws onto the driver tips. It makes guiding the screw into cramped areas much easier and rubs right off afterwards.
I believe every single screw that I unscrewed required a Phillips #000 (instead of #0 or #00). Could just be my model. Great guide otherwise.
Following this guide, I fixed the balanced audio on my laptop. I appreciate your thorough instruction. My goal is to open a repair shop, but in order to do that, I must learn a lot from you. gartic phone
Bahçeşehir Konut Projeleri thanks for helpfull writing. this article very important and true.
