Introdução
Restore sound to your laptop by replacing the speaker.
Ferramentas
Peças
Remove ten Phillips screws securing the lower case to the MacBook Air:
Six 2.8 mm screws
Two 3.8 mm screws
Two 5.4 mm screws
Remove the following two screws securing the speaker assembly to the upper case.
One 3 mm Phillips.
One 5.8 mm Phillips.
Use the tip of a spudger to pry the speaker connector up off the audio board.
4 outras pessoas concluíram este guia.
