Introdução
Don't pay Apple to replace your worn out battery. Do it yourself!
O que você precisa
Vídeo de Apresentação
Remove ten Phillips screws securing the lower case to the MacBook Air:
Six 2.8 mm screws
Two 3.8 mm screws
Two 5.4 mm screws
Lift the battery out of the Air.
Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
116 outras pessoas executaram este guia.
12 comentários
This doesn't make sense. The battery cost $110, plus shipping, which will come out to about $130, with next day shipping. Apple does it for $129, and will do it same day with an appointment. I know some people will do it for fun, but if you're trying to save money, I have to roll with Apple on this one.
I ordered a replacement battery for $75 (shipping included) and 3 days later the switch is done (thanks for this easy guide!). Now, my wife's MBA is free from power cord again! It is a no brainer!
I have bought the This replacment a1245 battey - A1237 and A1304 Battery
thanks for the install guide
Did it in minutes...cheaper than authorized Apple guy was charging me...machine works like a charm again. Thanks MJ & iFixit. :)
Other guides mention from late 2010 onwards Apple use 5-star anti-tamper screws on the bottom lid. So such a bit is useful on those later models.
Any idea where to buy the two screws of the battery? One of mine is spread and unusable.
The battery change is very simple. But now the battery isn't loading. The macbookair sees the battery but say not loading. loader was good and gives a green light.
who can help me? peter.vd.raad@hetnet.nl
Thanks for this guide and all the others. iFixit it literally the greatest site in the universe. People come here from other galaxies just to watch the video guides. MJ is beautiful and she knows her stuff so she makes doing a fix much easier with her comforting personality.
