Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Internal Prerequisite.
O que você precisa
Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
Be sure you are prying up on the hinged retaining flap, not the socket itself.
Gently push the tip of a spudger under the black plastic flap stuck to the display data cable lock to make the lock pop upward and away from the socket.
While holding the lock away from the socket, use the tip of a spudger and your fingers to gently remove the display data cable from its socket.
4 outras pessoas executaram este guia.
Um comentário
Excellent guide, thank you very much.
Logic board removed from my daughter’s Air, cooked for 8m at 200C, cooled, reinstalled, and now works again.
I was able to remove and replace the 5th heatsink retaining screw without moving the antenna retainer.
Cheers, Aidan
