Introdução
Left side of your Air mute these days? Use this guide to replace your left speaker.
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
9 outras pessoas concluíram este guia.
