Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Ferramenta utilizada nesse passo:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Com uma chave Pentalobe P5, remova dez parafusos que fixam a estrutura inferior, com os seguintes comprimentos:
Dois parafusos de 9 mm
Oito parafusos de 2,6 mm
Este passo não foi traduzido. Ajude a traduzi-lo
Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
Use the flat end of a spudger to pry the I/O board cable connector upward out of its socket on the I/O board.
Carefully peel the I/O board cable from the top of the fan.
While gently pulling the I/O board cable upward near its connection to the logic board, use the tip of a spudger to pry upward on alternating sides of the connector to help "walk" it out of its socket.
Remove the I/O board cable.
Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
Peel the rubber gasket off the adhesive on the top of the fan.
Remove the following three screws securing the fan to the upper case:
One 3.6 mm T5 Torx screw
One 2.7 mm T5 Torx screw
One 3.6 mm T5 Torx screw with a short head
Lift the fan out of the upper case and carefully pull the fan ribbon cable out of its socket as you remove it from the Air.
46 outras pessoas executaram este guia.
6 comentários
I also broke the retaining flap. For now, I just reinserted the ribbon. Is the function of the retaining flap just to hold the ribbon in place? Since then my computer has been entering sleep mode/shutting down during use, but I also did a battery replacement recently.
Good stuff! Thanks.
VFRDon
Got it flawlessly! Thanks!
