Ir para o conteúdo principal
MacBook Air 13" Late 2010 Solid-State Drive Replacement
O que você precisa
Vídeo de Apresentação
  1. MacBook Air 13" Late 2010 Solid-State Drive Replacement, Lower Case: passo 1, imagem 1 %32
    Ferramenta utilizada nesse passo:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Comprar
    • Before proceeding, power off the device, close the lid and lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 9 mm 5-point Pentalobe screws
    • Eight 2.6 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the eight 5-point Pentalobe screws can be found here.
  2. MacBook Air 13" Late 2010 Solid-State Drive Replacement: passo 2, imagem 1 %32
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 13" Late 2010 Solid-State Drive Replacement, Battery: passo 3, imagem 1 %32
    • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
    • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
    • Do not lift upward on the connector as you disconnect it.
  4. MacBook Air 13" Late 2010 Solid-State Drive Replacement, Solid-State Drive: passo 4, imagem 1 %32
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
  5. MacBook Air 13" Late 2010 Solid-State Drive Replacement: passo 5, imagem 1 %32
    • Do not lift the end of the SSD excessively.
    • Slightly lift up the end of the SSD and pull it straight out of its socket on the logic board.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
Conclusão
24 outras pessoas executaram este guia.
3 comentários
What's the best external enclosure for a potential dead MacBook Air in order to grab info off of?
enicolas - Responder
Hey there, same question as above, are there any adapters (to USB, for example) out there to get back data from the hard drive with that proprietary pin connector in case the Mac is not operational anymore?
ghislain.bourgin - Responder
For all I know you may have found something by now but for anyone else who asks this question you can get an adapter to adapt it to a normal m.2 or nvme connection and then all you need to do is get a standard adapter which may be a little more useful for use with pc’s as well
Declan -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 51
Últimos 30 dias: 205
Duração total: 128,751
