Introdução
Use this guide to replace a damaged MacBook Air 13" Early 2015 lower case.
O que você precisa
Ferramenta utilizada nesse passo:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
16 outras pessoas executaram este guia.
Um comentário
Not sure how this is considered “Moderate” difficulty… It doesn’t get any more simple than this, does it?
