Ir para o conteúdo principal
MacBook Air 11" Mid 2013 Upper Case Replacement
O que você precisa
  1. MacBook Air 11" Mid 2013 Upper Case Replacement, Lower Case: passo 1, imagem 1 %32
    Ferramenta utilizada neste passo:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Mid 2013 Upper Case Replacement: passo 2, imagem 1 %32
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Mid 2013 Upper Case Replacement, Battery Connector: passo 3, imagem 1 %32 MacBook Air 11" Mid 2013 Upper Case Replacement, Battery Connector: passo 3, imagem 2 %32
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
  4. MacBook Air 11" Mid 2013 Upper Case Replacement, I/O Board Cable: passo 4, imagem 1 %32 MacBook Air 11" Mid 2013 Upper Case Replacement, I/O Board Cable: passo 4, imagem 2 %32
    • Use the flat end of a spudger to pry the left and right I/O board cable connectors up off their respective sockets on the I/O board.
  5. MacBook Air 11" Mid 2013 Upper Case Replacement: passo 5, imagem 1 %32
    • Lift and remove the I/O board cable.
  6. MacBook Air 11" Mid 2013 Upper Case Replacement, Fan: passo 6, imagem 1 %32 MacBook Air 11" Mid 2013 Upper Case Replacement, Fan: passo 6, imagem 2 %32
    • Use the tip of a spudger to carefully push on each side of the iSight camera cable connector to loosen it out of its socket on the logic board.
    • We recommend you gently "walk" the connector out of its socket.
  7. MacBook Air 11" Mid 2013 Upper Case Replacement: passo 7, imagem 1 %32 MacBook Air 11" Mid 2013 Upper Case Replacement: passo 7, imagem 2 %32
    • Peel the iSight camera cable up off the adhesive securing it to the fan.
  8. MacBook Air 11" Mid 2013 Upper Case Replacement: passo 8, imagem 1 %32 MacBook Air 11" Mid 2013 Upper Case Replacement: passo 8, imagem 2 %32
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  9. MacBook Air 11" Mid 2013 Upper Case Replacement: passo 9, imagem 1 %32
    • Remove the following three screws securing the fan to the upper case:
    • Two 5.5 mm T5 Torx screws
    • One 4.6 mm T5 Torx screw
    • In some models this is a 3.6 mm T5 Torx screw.
  10. MacBook Air 11" Mid 2013 Upper Case Replacement: passo 10, imagem 1 %32 MacBook Air 11" Mid 2013 Upper Case Replacement: passo 10, imagem 2 %32 MacBook Air 11" Mid 2013 Upper Case Replacement: passo 10, imagem 3 %32
    • Lift, but do not remove the fan out of its recess in the upper case.
    • Carefully pull the fan ribbon cable out of its socket as you remove the fan from the Air.
  11. MacBook Air 11" Mid 2013 Upper Case Replacement, Logic Board Assembly: passo 11, imagem 1 %32 MacBook Air 11" Mid 2013 Upper Case Replacement, Logic Board Assembly: passo 11, imagem 2 %32 MacBook Air 11" Mid 2013 Upper Case Replacement, Logic Board Assembly: passo 11, imagem 3 %32
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card, and move them out of the way.
  12. MacBook Air 11" Mid 2013 Upper Case Replacement: passo 12, imagem 1 %32
    • Remove the following five screws securing the battery to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
  13. MacBook Air 11" Mid 2013 Upper Case Replacement: passo 13, imagem 1 %32
    • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
  14. MacBook Air 11" Mid 2013 Upper Case Replacement: passo 14, imagem 1 %32 MacBook Air 11" Mid 2013 Upper Case Replacement: passo 14, imagem 2 %32
    • Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the front edge of the Air.
  15. MacBook Air 11" Mid 2013 Upper Case Replacement: passo 15, imagem 1 %32 MacBook Air 11" Mid 2013 Upper Case Replacement: passo 15, imagem 2 %32 MacBook Air 11" Mid 2013 Upper Case Replacement: passo 15, imagem 3 %32
    • Use the tip of a spudger to de-route the antenna cables from their notches in the logic board.
  16. MacBook Air 11" Mid 2013 Upper Case Replacement: passo 16, imagem 1 %32 MacBook Air 11" Mid 2013 Upper Case Replacement: passo 16, imagem 2 %32 MacBook Air 11" Mid 2013 Upper Case Replacement: passo 16, imagem 3 %32
    • Gently push the tip of a spudger under the black plastic flap stuck to the display data cable lock to make the lock pop upward and away from the socket.
    • While holding the lock away from the socket, gently pull the display data cable out of its socket.
    • Do not pull upward on the display data cable as you disconnect it, as its socket may break off the logic board.
  17. MacBook Air 11" Mid 2013 Upper Case Replacement: passo 17, imagem 1 %32 MacBook Air 11" Mid 2013 Upper Case Replacement: passo 17, imagem 2 %32 MacBook Air 11" Mid 2013 Upper Case Replacement: passo 17, imagem 3 %32
    • Use the tip of a spudger to pry under the speaker cable connector, lifting it straight up from its socket.
    • De-route the cable from its notch in the logic board.
  18. MacBook Air 11" Mid 2013 Upper Case Replacement: passo 18, imagem 1 %32 MacBook Air 11" Mid 2013 Upper Case Replacement: passo 18, imagem 2 %32 MacBook Air 11" Mid 2013 Upper Case Replacement: passo 18, imagem 3 %32
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
    • Pull the trackpad ribbon cable straight out of its socket toward the front edge of the Air.
  19. MacBook Air 11" Mid 2013 Upper Case Replacement: passo 19, imagem 1 %32 MacBook Air 11" Mid 2013 Upper Case Replacement: passo 19, imagem 2 %32 MacBook Air 11" Mid 2013 Upper Case Replacement: passo 19, imagem 3 %32
    • Use the tip of a spudger to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
    • Pull the keyboard backlight ribbon cable out of its socket.
  20. MacBook Air 11" Mid 2013 Upper Case Replacement: passo 20, imagem 1 %32
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
  21. MacBook Air 11" Mid 2013 Upper Case Replacement: passo 21, imagem 1 %32 MacBook Air 11" Mid 2013 Upper Case Replacement: passo 21, imagem 2 %32 MacBook Air 11" Mid 2013 Upper Case Replacement: passo 21, imagem 3 %32
    • Slightly lift the free end of the AirPort/Bluetooth board and pull it out of its socket on the logic board.
    • To avoid damaging its socket on the logic board, do not excessively lift the free end of the AirPort/Bluetooth card.
  22. MacBook Air 11" Mid 2013 Upper Case Replacement: passo 22, imagem 1 %32
    • Remove the three 3.6 mm T5 Torx screws securing the logic board to the upper case.
    • In some models these are 3.1 mm T5 Torx screws.
  23. MacBook Air 11" Mid 2013 Upper Case Replacement: passo 23, imagem 1 %32 MacBook Air 11" Mid 2013 Upper Case Replacement: passo 23, imagem 2 %32 MacBook Air 11" Mid 2013 Upper Case Replacement: passo 23, imagem 3 %32
    • Gently lift the logic board assembly from the heat sink end and pull it away from the port side of the case to remove it from the Air.
    • When replacing the logic board, insert the board's rubber edge under the port-side rubber gasket, then lower the board into place.
  24. MacBook Air 11" Mid 2013 Upper Case Replacement, I/O Board: passo 24, imagem 1 %32 MacBook Air 11" Mid 2013 Upper Case Replacement, I/O Board: passo 24, imagem 2 %32 MacBook Air 11" Mid 2013 Upper Case Replacement, I/O Board: passo 24, imagem 3 %32
    • Remove the small rubber gasket from the corner of the upper case nearest the the I/O board.
    • Remove the gasket from the corner nearest display cable connector.
  25. MacBook Air 11" Mid 2013 Upper Case Replacement: passo 25, imagem 1 %32 MacBook Air 11" Mid 2013 Upper Case Replacement: passo 25, imagem 2 %32
    • If necessary, use tweezers to remove any tape covering the microphone cable ZIF connector.
  26. MacBook Air 11" Mid 2013 Upper Case Replacement: passo 26, imagem 1 %32 MacBook Air 11" Mid 2013 Upper Case Replacement: passo 26, imagem 2 %32 MacBook Air 11" Mid 2013 Upper Case Replacement: passo 26, imagem 3 %32
    • Use the tip of a spudger to carefully flip up the retaining flap on the microphone cable ZIF socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • With a pair of tweezers, pull the microphone ribbon cable straight out of its socket.
  27. MacBook Air 11" Mid 2013 Upper Case Replacement: passo 27, imagem 1 %32 MacBook Air 11" Mid 2013 Upper Case Replacement: passo 27, imagem 2 %32 MacBook Air 11" Mid 2013 Upper Case Replacement: passo 27, imagem 3 %32
    • Use the tip of a spudger to pry under the speaker cable near the connector, lifting it straight up from its socket.
  28. MacBook Air 11" Mid 2013 Upper Case Replacement: passo 28, imagem 1 %32
    • Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
  29. MacBook Air 11" Mid 2013 Upper Case Replacement: passo 29, imagem 1 %32 MacBook Air 11" Mid 2013 Upper Case Replacement: passo 29, imagem 2 %32 MacBook Air 11" Mid 2013 Upper Case Replacement: passo 29, imagem 3 %32
    • Carefully lift the I/O board by its power cable and pull it away from the edge of the case.
  30. MacBook Air 11" Mid 2013 Upper Case Replacement, Display Assembly: passo 30, imagem 1 %32 MacBook Air 11" Mid 2013 Upper Case Replacement, Display Assembly: passo 30, imagem 2 %32 MacBook Air 11" Mid 2013 Upper Case Replacement, Display Assembly: passo 30, imagem 3 %32
    • Peel up the six cable loops securing the antenna cables to the upper case.
    • In some models there are seven cable loops.
    • Gently pull the cable loops slightly out of the channel cut into the upper case one at a time.
    • Use your spudger to open up the plastic loops as you de-route the antenna cables through them.
    • Repeat this for each retaining loop until the antenna cables are free from the upper case.
  31. MacBook Air 11" Mid 2013 Upper Case Replacement: passo 31, imagem 1 %32 MacBook Air 11" Mid 2013 Upper Case Replacement: passo 31, imagem 2 %32
    • Remove the inner 4.9 mm T8 Torx screw securing each display hinge to the upper case (two screws total).
  32. MacBook Air 11" Mid 2013 Upper Case Replacement: passo 32, imagem 1 %32
    • Open the display until it is perpendicular to the upper case and place it on a table as shown.
    • While holding the Air steady, remove the remaining 4.9 mm T8 Torx screw from the lower display bracket.
  33. MacBook Air 11" Mid 2013 Upper Case Replacement: passo 33, imagem 1 %32
    • Before removing the last display screw, be sure to hold the display and upper case steady with your other hand. Failure to do so may allow the components to fall onto the table, causing potentially expensive damage.
    • Remove the last 4.9 mm T8 Torx screw securing the display to the upper case.
  34. MacBook Air 11" Mid 2013 Upper Case Replacement: passo 34, imagem 1 %32 MacBook Air 11" Mid 2013 Upper Case Replacement: passo 34, imagem 2 %32
    • Push the upper case slightly toward the display assembly, then rotate it away from the front of the display assembly.
    • Once the two display hinges have cleared the upper case, remove the display.
  35. MacBook Air 11" Mid 2013 Upper Case Replacement, Upper Case: passo 35, imagem 1 %32 MacBook Air 11" Mid 2013 Upper Case Replacement, Upper Case: passo 35, imagem 2 %32
    • Use the flat end of a spudger to pry the right speaker off the adhesive securing it to the upper case.
    • Only pry up on the speaker from the areas of bare aluminum on the upper case. Prying up from the keyboard area may damage the keyboard and the speaker itself.
    • Remove the right speaker from the upper case.
  36. MacBook Air 11" Mid 2013 Upper Case Replacement: passo 36, imagem 1 %32 MacBook Air 11" Mid 2013 Upper Case Replacement: passo 36, imagem 2 %32
    • Use the flat end of a spudger to pry the left speaker off the adhesive securing it to the upper case.
    • Remove the left speaker from the upper case.
  37. MacBook Air 11" Mid 2013 Upper Case Replacement: passo 37, imagem 1 %32 MacBook Air 11" Mid 2013 Upper Case Replacement: passo 37, imagem 2 %32
    • Use the tip of a spudger to pry the microphone away from the side of the upper case.
    • Remove the microphone from the upper case.
    • Upper case remains.
  38. MacBook Air 11" Mid 2013 Upper Case Replacement, Upper Case: passo 38, imagem 1 %32 MacBook Air 11" Mid 2013 Upper Case Replacement, Upper Case: passo 38, imagem 2 %32 MacBook Air 11" Mid 2013 Upper Case Replacement, Upper Case: passo 38, imagem 3 %32
    • The ZIF connector for the keyboard ribbon cable is hidden under the cable itself.
    • Push/lift the keyboard ribbon cable off of the upper case with one hand.
    • With the other hand, use a spudger to flip up the retaining flap on the ZIF connector.
    • Once the retaining flap has been flipped up, carefully pull the ribbon cable straight out of its socket.
  39. MacBook Air 11" Mid 2013 Upper Case Replacement: passo 39, imagem 1 %32 MacBook Air 11" Mid 2013 Upper Case Replacement: passo 39, imagem 2 %32
    • Use the flat end of a spudger to separate the trackpad ribbon cable from the underside of the keyboard.
    • The cable is held in place with adhesive. Work carefully, and be sure to not let the spudger slip and damage any components.
  40. MacBook Air 11" Mid 2013 Upper Case Replacement: passo 40, imagem 1 %32
    • Remove the six 1.5 mm Phillips #00 screws securing the trackpad to the upper case.
    • Check your replacement upper case—if it doesn't have this wide T5 screw, remove it to transfer into the replacement.
    • This is an adjustment screw to set the distance of the click of the trackpad—on reassembly, test the click and adjust this screw until it feels right.
  41. MacBook Air 11" Mid 2013 Upper Case Replacement: passo 41, imagem 1 %32 MacBook Air 11" Mid 2013 Upper Case Replacement: passo 41, imagem 2 %32 MacBook Air 11" Mid 2013 Upper Case Replacement: passo 41, imagem 3 %32
    • Holding the upper case up off the table with one hand, gently push the trackpad up through the upper case.
    • Remove the trackpad from the upper case.
  42. MacBook Air 11" Mid 2013 Upper Case Replacement: passo 42, imagem 1 %32
    • The upper case remains.
Conclusão
21 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
474.960 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.629 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 34
Ao todo: 12,130
