Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
MacBook Air 11" Mid 2013 I/O Board Replacement
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. MacBook Air 11" Mid 2013 I/O Board Replacement, I/O Board: passo 1, imagem 1 %32 MacBook Air 11" Mid 2013 I/O Board Replacement, I/O Board: passo 1, imagem 2 %32 MacBook Air 11" Mid 2013 I/O Board Replacement, I/O Board: passo 1, imagem 3 %32
    • Remove the small rubber gasket from the corner of the upper case nearest the the I/O board.
    • Remove the gasket from the corner nearest display cable connector.
  2. MacBook Air 11" Mid 2013 I/O Board Replacement: passo 2, imagem 1 %32 MacBook Air 11" Mid 2013 I/O Board Replacement: passo 2, imagem 2 %32
    • If necessary, use tweezers to remove any tape covering the microphone cable ZIF connector.
  3. MacBook Air 11" Mid 2013 I/O Board Replacement: passo 3, imagem 1 %32 MacBook Air 11" Mid 2013 I/O Board Replacement: passo 3, imagem 2 %32 MacBook Air 11" Mid 2013 I/O Board Replacement: passo 3, imagem 3 %32
    • Use the tip of a spudger to carefully flip up the retaining flap on the microphone cable ZIF socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • With a pair of tweezers, pull the microphone ribbon cable straight out of its socket.
  4. MacBook Air 11" Mid 2013 I/O Board Replacement: passo 4, imagem 1 %32 MacBook Air 11" Mid 2013 I/O Board Replacement: passo 4, imagem 2 %32 MacBook Air 11" Mid 2013 I/O Board Replacement: passo 4, imagem 3 %32
    • Use the tip of a spudger to pry under the speaker cable near the connector, lifting it straight up from its socket.
    • De-route the cable from its notch in the logic board.
  5. MacBook Air 11" Mid 2013 I/O Board Replacement: passo 5, imagem 1 %32
    • Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
  6. MacBook Air 11" Mid 2013 I/O Board Replacement: passo 6, imagem 1 %32 MacBook Air 11" Mid 2013 I/O Board Replacement: passo 6, imagem 2 %32 MacBook Air 11" Mid 2013 I/O Board Replacement: passo 6, imagem 3 %32
    • Carefully lift the I/O board by its power cable and pull it away from the edge of the case.
Conclusão
Sam Goldheart
Membro desde: 10/18/12
465.602 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.718 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 88
