Ir para o conteúdo principal
MacBook Air 11" Mid 2011 Solid-State Drive Replacement
O que você precisa
  1. MacBook Air 11" Mid 2011 Solid-State Drive Replacement, Lower Case: passo 1, imagem 1 %32
    Ferramenta utilizada neste passo:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Before proceeding, close your computer and lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the eight 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Mid 2011 Solid-State Drive Replacement: passo 2, imagem 1 %32
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Mid 2011 Solid-State Drive Replacement, Battery: passo 3, imagem 1 %32 MacBook Air 11" Mid 2011 Solid-State Drive Replacement, Battery: passo 3, imagem 2 %32
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
  4. MacBook Air 11" Mid 2011 Solid-State Drive Replacement, Solid-State Drive: passo 4, imagem 1 %32
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
  5. MacBook Air 11" Mid 2011 Solid-State Drive Replacement: passo 5, imagem 1 %32 MacBook Air 11" Mid 2011 Solid-State Drive Replacement: passo 5, imagem 2 %32
    • Use a spudger to help lift the free end of the SSD just enough to grab it with your other hand.
    • Do not lift the end of the SSD excessively.
    • Pull the drive straight out of its socket and remove it from the logic board.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
Conclusão
116 outras pessoas executaram este guia.
16Comentários do guia
Note: if you're installing a blank SSD, you'll want to format it with Disk Utilities) before the OS X installer will recognize it.
aaronmiller - Responder Compartilhar
Could not have been any easier, with this guide.
Thank you very much!
916sp - Responder Compartilhar
is it possible to replace an 128 GB Solid State Drive with an 240 GB? (MacBook Air, 11", Mid 2011)
zimmermatthias - Responder Compartilhar
Does anyone know if the Samsung 960 pro 512gb m.2 drive is compatible with this machine?
Mark - Responder Compartilhar
No, is not, I just bought a 1TB Samsung 960 EVO m.2 and had to return it, for not being compatible. (is smaller and the pin-out is not the same)
fjlbandeira - Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 16
Últimos 7 dias: 89
Últimos 30 dias: 478
Ao todo: 255,947
