Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Ferramenta utilizada nesse passo:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99-
Remove the following ten screws:
Two 8 mm 5-point Pentalobe screws
Eight 2.5 mm 5-point Pentalobe screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
Use a spudger to help lift the free end of the SSD just enough to grab it with your other hand.
Pull the drive straight out of its socket and remove it from the logic board.
Use the flat end of a spudger to pry the I/O board cable up from its socket on the I/O board.
Peel the I/O board cable up from the adhesive securing it to the fan.
Use the flat end of a spudger to lift the I/O board connector up and out of its socket on the logic board
Remove the I/O board cable.
Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
Remove the following three screws securing the fan to the upper case:
Two 5.2 mm T5 Torx screws
One 3.6 mm T5 Torx screw
Lift the fan out of the upper case and carefully pull the fan ribbon cable out of its socket as you remove it from the Air.
Remove the following five screws securing the battery to the upper case:
One 6 mm T5 Torx screw
Two 2.6 mm T5 Torx screws
Lift the battery from its edge nearest the logic board and remove it from the upper case.
Use the flat end of a spudger to free the adhesive loop securing the I/O board power cable to the upper case.
Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
Use the tip of a spudger to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
Pull the keyboard backlight ribbon cable out of its socket.
Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
Pull the trackpad ribbon cable straight out of its socket toward the front edge of the Air.
Use the tip of a spudger to de-route the right speaker cable from the slot cut into the logic board.
Use the flat end of a spudger to pry the right speaker cable connector up and out of its socket on the logic board.
Gently push the tip of a spudger under the black plastic flap stuck to the display data cable lock to make the lock pop upward and away from the socket.
Remove the small rubber gasket from the corner of the upper case near the display data cable.
While holding the lock away from the socket, gently pull the display data cable out of its socket.
Use the flat end of a spudger to pry both antenna cable connectors up and off their sockets on the AirPort/Bluetooth card.
Gently de-route the antenna cables from the slot cut into the logic board.
Remove the three 3.6 mm T5 Torx screws securing the logic board to the upper case.
Gently lift the logic board assembly out of the upper case, minding the fragile heat sink and any cables that may get caught.
Remove the small rubber gasket from the corner of the upper case nearest the I/O board.
Use the tip of a spudger to carefully flip up the retaining flap on the microphone cable ZIF socket.
Pull the microphone ribbon cable straight out of its socket.
De-route the left speaker cable from the notch cut into the I/O board.
Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
Pull the camera cable parallel to the face of the I/O board toward the rear edge of the Air to disconnect it from its socket.
Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
Carefully lift the I/O board from its edge nearest the logic board and remove it from the upper case.
Peel up the six cable loops securing the antenna cables to the upper case.
Gently pull the cable loops slightly out of the channel cut into the upper case one at a time.
Use your spudger to open up the plastic loops as you de-route the antenna cables through them.
Repeat this for all of the retaining loops.
Remove the inner 4.9 mm T8 Torx screw securing each display hinge to the upper case (two screws total).
Open the display until it is perpendicular to the upper case and place it on a table as shown.
While holding the Air steady, remove the remaining 4.9 mm T8 Torx screw from the lower display bracket.
Remove the last 4.9 mm T8 Torx screw securing the display to the upper case.
Push the upper case slightly toward the display assembly, then rotate it away from the front of the display assembly.
Once the two display hinges have cleared the upper case, remove the display and set it aside.
71 outras pessoas executaram este guia.
5 comentários
Thanks a lot for this guide! My daughter wrecked the display on my Macbook Air. I have never done any repairs on a notebook before, but I ordered the new display assembly and the toolkit and went ahead anyways.
When I saw my Macbook Air in pieces before me, I had my doubts that it would ever work again, but placing the last screw and then pressing the power button, it just worked!
Thanks again!
Switched two monitors and made a great job thanks to this amzing guide. Very easy.
