Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Internal prerequisite.
O que você precisa
Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
Gently push the tip of a spudger under the black plastic flap stuck to the display data cable lock to make the lock pop upward and away from the socket.
While holding the lock away from the socket, use the tip of a spudger and your fingers to gently remove the display data cable from its socket.
