Ir para o conteúdo principal
Mac mini Model A1347 Optical Drive Replacement
O que você precisa
  1. Mac mini Model A1347 Optical Drive Replacement, Bottom Cover: passo 1, imagem 1 %32 Mac mini Model A1347 Optical Drive Replacement, Bottom Cover: passo 1, imagem 2 %32
    • Place your thumbs in the depressions cut into the bottom cover.
    • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
  2. Mac mini Model A1347 Optical Drive Replacement: passo 2, imagem 1 %32
    • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
    • Remove the bottom cover and set it aside.
  3. Mac mini Model A1347 Optical Drive Replacement, Fan: passo 3, imagem 1 %32
    • Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
  4. Mac mini Model A1347 Optical Drive Replacement: passo 4, imagem 1 %32
    • Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
    • If the fan doesn't separate from the standoff screw with a moderate amount of force, you can use a T6 Torx driver to simply remove this screw.
  5. Mac mini Model A1347 Optical Drive Replacement: passo 5, imagem 1 %32
    • Lift the fan out of the mini for enough clearance to access its connector.
    • Carefully pull the fan cables upward to lift the fan connector up out of its socket on the logic board.
    • Remove the fan.
  6. Mac mini Model A1347 Optical Drive Replacement, Cowling: passo 6, imagem 1 %32
    • Remove the single 3.5 mm T6 Torx screw securing the cowling to the heat sink.
  7. Mac mini Model A1347 Optical Drive Replacement: passo 7, imagem 1 %32
    • Lift the cowling from the end nearest the antenna plate.
    • Rotate the cowling away from the outer case and remove it from the mini.
  8. Mac mini Model A1347 Optical Drive Replacement, Antenna Plate: passo 8, imagem 1 %32
    • Remove the following screws securing the antenna plate to the mini:
    • Two 6.6 mm T8 or T9 Torx screws
    • Two 5.0 mm T8 Torx or 2.0 mm Hex screws (either will work)
  9. Mac mini Model A1347 Optical Drive Replacement: passo 9, imagem 1 %32 Mac mini Model A1347 Optical Drive Replacement: passo 9, imagem 2 %32
    • Slightly lift the antenna plate from the end closest to the RAM.
    • Carefully pull the antenna plate straight away from the circular rim of the outer case.
    • Do not remove the antenna plate yet. It is still attached to the AirPort/ Bluetooth board.
  10. Mac mini Model A1347 Optical Drive Replacement: passo 10, imagem 1 %32
    • Use the tip of a spudger to carefully pry the antenna connector up off the AirPort/Bluetooth board.
  11. Mac mini Model A1347 Optical Drive Replacement: passo 11, imagem 1 %32
    • Remove the antenna plate from the mini.
  12. Mac mini Model A1347 Optical Drive Replacement, Logic Board: passo 12, imagem 1 %32
    • Remove the following three screws:
    • One 5.0 mm T8 Torx or 2.0 mm Hex screw (either will work)
    • One 16.2 mm T6 Torx screw
    • One 26 mm T6 Torx standoff
  13. Mac mini Model A1347 Optical Drive Replacement: passo 13, imagem 1 %32 Mac mini Model A1347 Optical Drive Replacement: passo 13, imagem 2 %32
    • Carefully pull the wires for both hard drive thermal sensors upward to lift their connectors up and out of the sockets on the logic board.
  14. Mac mini Model A1347 Optical Drive Replacement: passo 14, imagem 1 %32 Mac mini Model A1347 Optical Drive Replacement: passo 14, imagem 2 %32
    • Use the flat end of a spudger to pry both the hard drive and optical drive connectors up out of their sockets on the logic board.
  15. Mac mini Model A1347 Optical Drive Replacement: passo 15, imagem 1 %32
    • To disconnect the optical drive thermal sensor, pinch its cables between your thumb and a spudger and pry the spudger upward to lift the connector up and out of its socket on the logic board.
  16. Mac mini Model A1347 Optical Drive Replacement: passo 16, imagem 1 %32
    • Use the tip of a spudger to lift the IR sensor connector up and out of its socket on the logic board.
  17. Mac mini Model A1347 Optical Drive Replacement: passo 17, imagem 1 %32 Mac mini Model A1347 Optical Drive Replacement: passo 17, imagem 2 %32 Mac mini Model A1347 Optical Drive Replacement: passo 17, imagem 3 %32
    Ferramenta utilizada neste passo:
    Mac mini Logic Board Removal Tool
    • To remove the logic board, two cylindrical rods must be inserted into the holes highlighted in red. Inserting instruments into any logic board holes other than the ones highlighted in red may destroy the logic board.
    • Insert a Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure it makes contact with the outer case below the logic board before proceeding.
    • If you don't have a Logic Board Removal Tool handy, you can use two tools having a maximum diameter of 2.5 mm instead. Just insert one into each of the highlighted holes.
    • Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
    • Cease prying when the I/O board is visibly separated from the outer case. Remove the Mac mini Logic Board Removal tool.
  18. Mac mini Model A1347 Optical Drive Replacement: passo 18, imagem 1 %32
    • Simultaneously push the two plastic clips on the far left and right sides of the I/O board toward the middle of the I/O board and pull the I/O board away from the outer case.
  19. Mac mini Model A1347 Optical Drive Replacement: passo 19, imagem 1 %32
    • Pull the I/O board/logic board assembly out of the outer case enough to access the power connector.
    • Use a pair of tweezers to disconnect the power cable from the logic board.
    • Pull the power cable connector toward the optical drive opening.
  20. Mac mini Model A1347 Optical Drive Replacement: passo 20, imagem 1 %32
    • Carefully slide the logic board assembly out of the mini, minding any cables that may get caught.
  21. Mac mini Model A1347 Optical Drive Replacement, Power Supply: passo 21, imagem 1 %32
    • Remove the 7.9 mm T6 Torx screw securing the power supply and optical drive to the outer case.
  22. Mac mini Model A1347 Optical Drive Replacement: passo 22, imagem 1 %32 Mac mini Model A1347 Optical Drive Replacement: passo 22, imagem 2 %32
    • Pull the silver metal AC-In socket retainer away from the side of the outer case and remove it from the mini.
  23. Mac mini Model A1347 Optical Drive Replacement: passo 23, imagem 1 %32 Mac mini Model A1347 Optical Drive Replacement: passo 23, imagem 2 %32
    • Rotate the AC-In connector 90 degrees counter-clockwise.
  24. Mac mini Model A1347 Optical Drive Replacement: passo 24, imagem 1 %32
    • Slide the power supply out of the mini, minding any cables that may get caught.
  25. Mac mini Model A1347 Optical Drive Replacement, Optical Drive: passo 25, imagem 1 %32
    • Remove the hard drive from the mini, minding any cables that may get caught.
  26. Mac mini Model A1347 Optical Drive Replacement: passo 26, imagem 1 %32
    • Remove the 7.9 mm T6 Torx screw securing the optical drive to the outer case.
  27. Mac mini Model A1347 Optical Drive Replacement: passo 27, imagem 1 %32
    • Slide the optical drive out of the outer case, minding any cables that may get caught.
  28. Mac mini Model A1347 Optical Drive Replacement, Optical Drive: passo 28, imagem 1 %32
    • Carefully de-route the IR sensor cables from the channel in the optical drive bracket.
  29. Mac mini Model A1347 Optical Drive Replacement: passo 29, imagem 1 %32 Mac mini Model A1347 Optical Drive Replacement: passo 29, imagem 2 %32
    • Remove the two 6.3 mm T6 Torx screws securing both sides of the optical drive bracket to the optical drive (four screws total).
  30. Mac mini Model A1347 Optical Drive Replacement: passo 30, imagem 1 %32
    • Remove the optical drive bracket from the optical drive, minding any cables that may get caught.
  31. Mac mini Model A1347 Optical Drive Replacement: passo 31, imagem 1 %32
    • Carefully peel the optical drive ribbon cable off the body of the optical drive.
  32. Mac mini Model A1347 Optical Drive Replacement: passo 32, imagem 1 %32
    • Disconnect the optical drive cable by pulling its connector away from the body of the optical drive.
  33. Mac mini Model A1347 Optical Drive Replacement: passo 33, imagem 1 %32
    • Peel off the strip of black tape covering the optical drive thermal sensor.
  34. Mac mini Model A1347 Optical Drive Replacement: passo 34, imagem 1 %32
    • Carefully pry the optical drive thermal sensor off the adhesive securing it to the optical drive.
    • It may be necessary to use a strip of tape or rubber cement to attach the thermal sensor to your new optical drive.
    • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
Conclusão
63 outras pessoas executaram este guia.
6Comentários do guia
Question; I've got this model Mac Mini and the optical drive has a disc stuck in it. Does anyone know if there is an emergency release mechanism anywhere? (I searched in the usual obvious places but was unable to find it.) I'm trying to determine whether I will need to remove the entire optical drive or not. (And even if I do, will that give me any greater access to the stuck CD -- assuming I don't smash the old optical drive with a proverbial hammer?)
David Das - Responder
Is it possible to just remove the optical drive entirely? I accidentally tore the thermal sensor connector completely off the motherboard when replacing the harddrive with a bigger one, and now the optical drive fan is running at full speed constantly.
Kristian Meller - Responder
The link for optical drive repair points to the wrong tutorial ( snow leopard installation) , at least on the french version.
Philippe Mas - Responder
It Works!!!!, new SSD placed instead of dvd drive TKS
Miguel Cartagenova - Responder
The Parts list indicates a 9.5mm drive, but from the pictures this one appears to be 12.7. Can anyone confirm which it is?
Conor Keenan - Responder
Comentar
Visualizações:
Últimas 24 horas: 18
Últimos 7 dias: 868
Últimos 30 dias: 2,521
Ao todo: 92,405
