Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
The time and date, as well as other settings, are kept by the PRAM battery when your machine is off.
O que você precisa
Power down your Mac mini, disconnect all of the cables, and flip it over.
Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
The Jimmy should reach a stop about 3/8" down.
We will first remove the AirPort antenna, located in the lower left corner of this picture.
Push the PRAM battery toward the center of the logic board and pull it up out of its holder. You'll have to push the battery in further than you'd expect in order to get it to pop free.
17 outras pessoas executaram este guia.
