O que você precisa
Remove the two Phillips screws connecting the underside of the hard drive to the internal frame.
Slide the hard drive toward the speaker to disconnect it from the interconnect board.
Lift the hard drive from the edge opposite the fan and remove it from the internal frame.
It was super frustrating getting the drive aligned, and when It finally did align, I forgot about the temperature sensor and managed to yank the wire out of the board. Hopefully I can adjust the fans manually and not have to reattach the wire, which doesn't really appear possible.
Anyone ever do it?
I wonder if the wire was the cause of my issue from the beginning, as now that the wire is gone, the drive slips right into place. So, if you're having difficulty getting the drive connected, make sure the temp sensor wire is out of the way.
So, looking back, I now see that the sensor cable routs on top of the drive, not underneath.
When putting a new drive in you need the spudger to hold the bottom of the drive in place though the side opening while you slide it into the sata connectors with your hand or a dull side of a screw driver. It wont damage anything [edit] (the spudger through the side hole) although it seems like you're forcing it. I did it twice because of the same problem with the wire getting caught. Rather than pull on the wire I just removed the drive and realigned the sensor. It's easy with the spudger.
عالی بود ممنونم
Um comentário
For all those poor people who have wrecked their Minis by following the bad advice on this page, I fixed mine by replacing this part:
http://www.powerbookmedic.com/Mac-Mini-I... (Apple part no 922-8807).
I did manage to solder a connector back onto the visible contacts on my original board, but it didn't work; the replacement worked fine.
If your cable is damaged too, you'll need to replace that too, but note that there are several different ones, and SKU17434 (Apple part 922-7319) is NOT compatible with the above board. I don't know the exact model of cable - having received the wrong one I managed to repair my original one.
These are JIS screws. A J1 bit will fit better than a PH1 bit.
michael - Responder
