Introdução
Replacing the bottom housing requires removing nearly every component of your mini.
Peças
Nenhum componente especificado.
Power down your Mac mini, disconnect all of the cables, and flip it over.
Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
The Jimmy should reach a stop about 3/8" down.
Slightly squeeze the two retaining arms toward each other and lift the AirPort antenna off its post.
Firmly grasp the power button cable connector with a pair of tweezers and lift it straight up off the logic board.
Remove the single Phillips screw securing the audio board to the bottom housing.
10 outras pessoas concluíram este guia.
