Ir para o conteúdo principal
Mac mini Mid 2011 Logic Board Replacement
Pré-requisito somente
Este é um guia somente para pré-requisitos! Este guia faz parte de outro procedimento e não deve ser usado sozinho.
O que você precisa
  1. Mac mini Mid 2011 Logic Board Replacement, Logic Board: passo 1, imagem 1 %32 Mac mini Mid 2011 Logic Board Replacement, Logic Board: passo 1, imagem 2 %32
    • Use the flat end of a spudger to pry the hard drive connector up from its socket on the logic board.
  2. Mac mini Mid 2011 Logic Board Replacement: passo 2, imagem 1 %32
    • Use the tip of a spudger to lift the IR sensor connector up and out of its socket on the logic board.
    • Make sure to pry up from beneath the wires and not underneath the socket.
  3. Mac mini Mid 2011 Logic Board Replacement: passo 3, imagem 1 %32
    • Remove the following three screws:
    • One 5.0 mm T8 Torx or 2.0 mm Hex screw (either screwdriver will work)
    • One 16.2 mm T6 Torx screw
    • One 26 mm T6 Torx standoff
  4. Mac mini Mid 2011 Logic Board Replacement: passo 4, imagem 1 %32 Mac mini Mid 2011 Logic Board Replacement: passo 4, imagem 2 %32 Mac mini Mid 2011 Logic Board Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    Mac mini Logic Board Removal Tool
    • To remove the logic board, the two cylindrical rods of the Mac mini Logic Board Removal Tool must be inserted into the holes highlighted in red. Inserting instruments into any logic board holes other than the ones highlighted in red may destroy the logic board.
    • Insert the Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure it makes contact with the top side of outer case below the logic board before proceeding.
    • Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
    • Cease prying when the I/O board is visibly separated from the outer case.
    • Remove the Mac mini Logic Board Removal tool.
  5. Mac mini Mid 2011 Logic Board Replacement: passo 5, imagem 1 %32
    • Pull the I/O board/logic board assembly out of the outer case enough to access the power connector.
    • Use your fingers to disconnect the DC-In cable from the logic board.
    • Pull the power cable connector toward the front side of the mini.
  6. Mac mini Mid 2011 Logic Board Replacement: passo 6, imagem 1 %32
    • Carefully slide the logic board assembly out of the mini, minding any cables that may get caught.
Linha de Chegada
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Ao todo: 1,475
