Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Remove the bottom cover to access components inside your Mac mini Mid 2011.
O que você precisa
Place your thumbs in the depressions cut into the bottom cover.
Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
17 outras pessoas executaram este guia.
2 comentários
Nailed it man
The base plate on my MM has no thumb dimples, no “lock dots”, and it won’t budge. I’ve tried everything short of prying it off—light touch, firm touch, thumbs, palm, nothing has worked. Any suggestions?
