Ir para o conteúdo principal
Mac mini Late 2018 Bottom Cover Replacement
O que você precisa
  1. Mac mini Late 2018 Bottom Cover Replacement, Bottom Cover: passo 1, imagem 1 %32
    • Power off and unplug your Mac mini before you begin.
    • Use an opening tool to pry the bottom cover up off of the Mac mini.
    I got as far as this step to do one thing, blow out all the dust. It was far enough and a lot of dust came out. I used a XPower A-2S to blow out the dust.
    nirv - Responder
  2. Mac mini Late 2018 Bottom Cover Replacement: passo 2, imagem 1 %32 Mac mini Late 2018 Bottom Cover Replacement: passo 2, imagem 2 %32
    • Lift and remove the bottom cover.
    • To reinstall the cover:
    • Align it carefully so that the words "Mac mini" can be read when the ports are facing you.
    • Then, press down on the cover to snap its three hidden clips into place.
    My antenna plate seems to have TR7 Torx security screws
    DougPA - Responder
    My Screws were also TR7, 2020 build
    Eric Ford - Responder
Conclusão
Jeff Suovanen
Membro desde: 08/06/13
428.095 Reputação
Autoria de 259 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.816 guias
2 comentários
Where can i find the cover itself for MM 2018?
avxkim - Responder
Check eBay for unibody Mac mini bottom covers. You can also 3D print one if you want to.
Forrest OHara -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 31
Últimos 30 dias: 134
Duração total: 8,256
