Ir para o conteúdo principal
Mac mini Late 2014 Speaker Replacement
O que você precisa
  1. Mac mini Late 2014 Speaker Replacement, Bottom Cover: passo 1, imagem 1 %32
    • The bottom cover is clipped onto three screw posts.
    • Pry near, but not right on the screw posts.
  2. Mac mini Late 2014 Speaker Replacement: passo 2, imagem 1 %32 Mac mini Late 2014 Speaker Replacement: passo 2, imagem 2 %32 Mac mini Late 2014 Speaker Replacement: passo 2, imagem 3 %32
    • Use the plastic opening tool to pry the bottom cover up off of the Mac mini.
  3. Mac mini Late 2014 Speaker Replacement: passo 3, imagem 1 %32 Mac mini Late 2014 Speaker Replacement: passo 3, imagem 2 %32
    • Lift and remove the bottom cover.
  4. Mac mini Late 2014 Speaker Replacement, Antenna Plate: passo 4, imagem 1 %32
    • Remove the following TR6 screws from the antenna plate:
    • Three 4.1 mm screws
    • Three 1.9 mm screws
  5. Mac mini Late 2014 Speaker Replacement: passo 5, imagem 1 %32 Mac mini Late 2014 Speaker Replacement: passo 5, imagem 2 %32
    • Do not completely remove the antenna plate; it is still connected to the Mac mini by an antenna cable.
    • With the I/O ports facing you, flip the antenna plate to the right to allow access to the antenna cable connector.
  6. Mac mini Late 2014 Speaker Replacement: passo 6, imagem 1 %32
    • Remove the single 3.4 mm T6 screw and washer from the antenna cable.
    • Be careful not to lose the washer when removing the screw.
  7. Mac mini Late 2014 Speaker Replacement: passo 7, imagem 1 %32 Mac mini Late 2014 Speaker Replacement: passo 7, imagem 2 %32
    • Use the point of a spudger to lift the antenna connector straight up off its socket on the airport card.
  8. Mac mini Late 2014 Speaker Replacement: passo 8, imagem 1 %32 Mac mini Late 2014 Speaker Replacement: passo 8, imagem 2 %32
    • Carefully pull the antenna cable out from the gap between the power supply and case.
  9. Mac mini Late 2014 Speaker Replacement: passo 9, imagem 1 %32
    • Remove the antenna plate from the Mac mini.
  10. Mac mini Late 2014 Speaker Replacement, Fan Assembly: passo 10, imagem 1 %32
    • Remove the two 12 mm T6 screws from the fan.
    • Loosen the 27 mm T6 captive screw–it will get removed with the fan assembly.
  11. Mac mini Late 2014 Speaker Replacement: passo 11, imagem 1 %32 Mac mini Late 2014 Speaker Replacement: passo 11, imagem 2 %32 Mac mini Late 2014 Speaker Replacement: passo 11, imagem 3 %32
    • The fan connector is trapped under the edge of the fan and cannot be disconnected until the fan is moved.
    • Do not attempt to remove the fan entirely.
    • Lift the fan straight up to free the captive screw from its hole in the logic board.
    • Pull the fan away from the SSD until you can easily access the fan connector.
  12. Mac mini Late 2014 Speaker Replacement: passo 12, imagem 1 %32 Mac mini Late 2014 Speaker Replacement: passo 12, imagem 2 %32
    • Use the point of a spudger to lift the fan connector straight up out of its socket on the logic board.
  13. Mac mini Late 2014 Speaker Replacement: passo 13, imagem 1 %32
    • Remove the fan from the Mac mini.
  14. Mac mini Late 2014 Speaker Replacement, Logic Board Assembly: passo 14, imagem 1 %32
    • Remove the 2.6 mm T6 screw securing the SATA cable connector bracket.
  15. Mac mini Late 2014 Speaker Replacement: passo 15, imagem 1 %32 Mac mini Late 2014 Speaker Replacement: passo 15, imagem 2 %32
    • Remove the SATA cable connector bracket.
  16. Mac mini Late 2014 Speaker Replacement: passo 16, imagem 1 %32 Mac mini Late 2014 Speaker Replacement: passo 16, imagem 2 %32
    • Use the flat end of a spudger to lift the SATA cable connector up off of its socket on the logic board.
  17. Mac mini Late 2014 Speaker Replacement: passo 17, imagem 1 %32 Mac mini Late 2014 Speaker Replacement: passo 17, imagem 2 %32
    • Use the tip of a spudger to disconnect the IR sensor cable connector by prying it straight up from its socket.
  18. Mac mini Late 2014 Speaker Replacement: passo 18, imagem 1 %32
    • The following three steps only apply to Mac minis equipped with a PCIe SSD. Skip the next three steps if your Mac mini only has a hard drive.
    • Remove the two 2.6 mm T6 screws securing the PCIe SSD cable bracket.
  19. Mac mini Late 2014 Speaker Replacement: passo 19, imagem 1 %32 Mac mini Late 2014 Speaker Replacement: passo 19, imagem 2 %32
    • Remove the PCIe SSD cable bracket.
  20. Mac mini Late 2014 Speaker Replacement: passo 20, imagem 1 %32 Mac mini Late 2014 Speaker Replacement: passo 20, imagem 2 %32
    • Lift the PCIe SSD connector up off its socket.
  21. Mac mini Late 2014 Speaker Replacement: passo 21, imagem 1 %32
    • Remove the single 16 mm T6 screw securing the logic board.
  22. Mac mini Late 2014 Speaker Replacement: passo 22, imagem 1 %32
    Ferramenta utilizada neste passo:
    Mac mini Logic Board Removal Tool
    • To remove the logic board, the two cylindrical rods of the Mac mini Logic Board Removal Tool must be inserted into the holes highlighted in red. Inserting instruments into any logic board holes other than the ones highlighted in red may destroy the logic board.
    • Insert the Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure the rods make contact with the case under the logic board before proceeding.
  23. Mac mini Late 2014 Speaker Replacement: passo 23, imagem 1 %32 Mac mini Late 2014 Speaker Replacement: passo 23, imagem 2 %32 Mac mini Late 2014 Speaker Replacement: passo 23, imagem 3 %32
    • Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
    • Cease prying when the removal tool makes contact with the opening in the rear case.
    • Remove the Mac mini Logic Board Removal tool.
  24. Mac mini Late 2014 Speaker Replacement: passo 24, imagem 1 %32 Mac mini Late 2014 Speaker Replacement: passo 24, imagem 2 %32
    • Pull the DC-In cable connector straight out of its socket on the logic board.
  25. Mac mini Late 2014 Speaker Replacement: passo 25, imagem 1 %32 Mac mini Late 2014 Speaker Replacement: passo 25, imagem 2 %32
    • Carefully slide the logic board assembly out of the Mac mini, minding any cables that may get caught.
  26. Mac mini Late 2014 Speaker Replacement, Speaker: passo 26, imagem 1 %32
    • Remove the following T6 Torx screws securing the speaker to the logic board:
    • One 3.6 mm screw
    • One 3.6 mm large headed screw
  27. Mac mini Late 2014 Speaker Replacement: passo 27, imagem 1 %32 Mac mini Late 2014 Speaker Replacement: passo 27, imagem 2 %32
    • Do not attempt to remove the speaker entirely as it is still attached to the logic board.
    • Nudge the speaker gently out of the way to allow access to the speaker's connector.
  28. Mac mini Late 2014 Speaker Replacement: passo 28, imagem 1 %32 Mac mini Late 2014 Speaker Replacement: passo 28, imagem 2 %32 Mac mini Late 2014 Speaker Replacement: passo 28, imagem 3 %32
    • Use the flat end of a spudger to carefully lift the speaker connector up out of its socket on the logic board.
    • Remove the speaker from the logic board.
Conclusão
Sam Goldheart
Membro desde: 10/18/12
471.486 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.416 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 73
Duração total: 5,944
