Ir para o conteúdo principal
Mac mini Late 2014 SSD Replacement
O que você precisa
  1. Mac mini Late 2014 SSD Replacement, Bottom Cover: passo 1, imagem 1 %32
    • The bottom cover is clipped onto three screw posts.
    • Pry near, but not right on the screw posts.
  2. Mac mini Late 2014 SSD Replacement: passo 2, imagem 1 %32 Mac mini Late 2014 SSD Replacement: passo 2, imagem 2 %32 Mac mini Late 2014 SSD Replacement: passo 2, imagem 3 %32
    • Use the plastic opening tool to pry the bottom cover up off of the Mac mini.
  3. Mac mini Late 2014 SSD Replacement: passo 3, imagem 1 %32 Mac mini Late 2014 SSD Replacement: passo 3, imagem 2 %32
    • Lift and remove the bottom cover.
  4. Mac mini Late 2014 SSD Replacement, Antenna Plate: passo 4, imagem 1 %32
    • Remove the following TR6 screws from the antenna plate:
    • Three 4.1 mm screws
    • Three 1.9 mm screws
  5. Mac mini Late 2014 SSD Replacement: passo 5, imagem 1 %32 Mac mini Late 2014 SSD Replacement: passo 5, imagem 2 %32
    • Do not completely remove the antenna plate; it is still connected to the Mac mini by an antenna cable.
    • With the I/O ports facing you, flip the antenna plate to the right to allow access to the antenna cable connector.
  6. Mac mini Late 2014 SSD Replacement: passo 6, imagem 1 %32
    • Remove the single 3.4 mm T6 screw and washer from the antenna cable.
    • Be careful not to lose the washer when removing the screw.
  7. Mac mini Late 2014 SSD Replacement: passo 7, imagem 1 %32 Mac mini Late 2014 SSD Replacement: passo 7, imagem 2 %32
    • Use the point of a spudger to lift the antenna connector straight up off its socket on the airport card.
  8. Mac mini Late 2014 SSD Replacement: passo 8, imagem 1 %32 Mac mini Late 2014 SSD Replacement: passo 8, imagem 2 %32
    • Carefully pull the antenna cable out from the gap between the power supply and case.
  9. Mac mini Late 2014 SSD Replacement: passo 9, imagem 1 %32
    • Remove the antenna plate from the Mac mini.
  10. Mac mini Late 2014 SSD Replacement, SSD: passo 10, imagem 1 %32
    • Remove the 5 mm T5 screw securing the SSD.
  11. Mac mini Late 2014 SSD Replacement: passo 11, imagem 1 %32 Mac mini Late 2014 SSD Replacement: passo 11, imagem 2 %32 Mac mini Late 2014 SSD Replacement: passo 11, imagem 3 %32
    • Lift the free end of the SSD up slightly and pull it out of its socket.
  12. Mac mini Late 2014 SSD Replacement: passo 12, imagem 1 %32 Mac mini Late 2014 SSD Replacement: passo 12, imagem 2 %32 Mac mini Late 2014 SSD Replacement: passo 12, imagem 3 %32
    • Carefully lift the SSD out of the case without scratching or touching the gold contacts.
Conclusão
110 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
477.219 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 25.675 guias
32Comentários do guia
If I have a Mac Mini without SSD, only with normal Hard Drive (NO Fusion). Can I install a new one SSD like on this tutorial?. Thanks!
Juan Miguel Ramirez - Responder Compartilhar
Please see my comment later in the thread.
Thomas Hall - Responder Compartilhar
Si, yo lo hice y la diferencia es abismal. Necesitaras un adaptador y por supuesto el SSD. Yes, I did it and the difference is abysmal. You will need an adapter and of course the SSD.
Manuel Jesús Flores Jiménez - Responder Compartilhar
Yes, but you need to add a cable to connect it. If you buy the SSD from OWC, they sell a kit which includes the cable and tools (for an extra $20-40, depending on what size/model SSD you get).
shamino - Responder Compartilhar
I have the same question as Juan
Cronan McNamara - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 13
Últimos 7 dias: 132
Últimos 30 dias: 599
Ao todo: 197,199
