Ir para o conteúdo principal
Mac mini Late 2014 PCIe SSD Cable Replacement
O que você precisa
  1. Mac mini Late 2014 PCIe SSD Cable Replacement, Bottom Cover: passo 1, imagem 1 %32
    • The bottom cover is clipped onto three screw posts.
    • Pry near, but not right on the screw posts.
  2. Mac mini Late 2014 PCIe SSD Cable Replacement: passo 2, imagem 1 %32 Mac mini Late 2014 PCIe SSD Cable Replacement: passo 2, imagem 2 %32 Mac mini Late 2014 PCIe SSD Cable Replacement: passo 2, imagem 3 %32
    • Use the plastic opening tool to pry the bottom cover up off of the Mac mini.
  3. Mac mini Late 2014 PCIe SSD Cable Replacement: passo 3, imagem 1 %32 Mac mini Late 2014 PCIe SSD Cable Replacement: passo 3, imagem 2 %32
    • Lift and remove the bottom cover.
  4. Mac mini Late 2014 PCIe SSD Cable Replacement, Antenna Plate: passo 4, imagem 1 %32
    • Remove the following TR6 screws from the antenna plate:
    • Three 4.1 mm screws
    • Three 1.9 mm screws
  5. Mac mini Late 2014 PCIe SSD Cable Replacement: passo 5, imagem 1 %32 Mac mini Late 2014 PCIe SSD Cable Replacement: passo 5, imagem 2 %32
    • Do not completely remove the antenna plate; it is still connected to the Mac mini by an antenna cable.
    • With the I/O ports facing you, flip the antenna plate to the right to allow access to the antenna cable connector.
  6. Mac mini Late 2014 PCIe SSD Cable Replacement: passo 6, imagem 1 %32
    • Remove the single 3.4 mm T6 screw and washer from the antenna cable.
    • Be careful not to lose the washer when removing the screw.
  7. Mac mini Late 2014 PCIe SSD Cable Replacement: passo 7, imagem 1 %32 Mac mini Late 2014 PCIe SSD Cable Replacement: passo 7, imagem 2 %32
    • Use the point of a spudger to lift the antenna connector straight up off its socket on the airport card.
  8. Mac mini Late 2014 PCIe SSD Cable Replacement: passo 8, imagem 1 %32 Mac mini Late 2014 PCIe SSD Cable Replacement: passo 8, imagem 2 %32
    • Carefully pull the antenna cable out from the gap between the power supply and case.
  9. Mac mini Late 2014 PCIe SSD Cable Replacement: passo 9, imagem 1 %32
    • Remove the antenna plate from the Mac mini.
  10. Mac mini Late 2014 PCIe SSD Cable Replacement, SSD: passo 10, imagem 1 %32
    • Remove the 5 mm T5 screw securing the SSD.
  11. Mac mini Late 2014 PCIe SSD Cable Replacement: passo 11, imagem 1 %32 Mac mini Late 2014 PCIe SSD Cable Replacement: passo 11, imagem 2 %32 Mac mini Late 2014 PCIe SSD Cable Replacement: passo 11, imagem 3 %32
    • Lift the free end of the SSD up slightly and pull it out of its socket.
  12. Mac mini Late 2014 PCIe SSD Cable Replacement: passo 12, imagem 1 %32 Mac mini Late 2014 PCIe SSD Cable Replacement: passo 12, imagem 2 %32 Mac mini Late 2014 PCIe SSD Cable Replacement: passo 12, imagem 3 %32
    • Carefully lift the SSD out of the case without scratching or touching the gold contacts.
  13. Mac mini Late 2014 PCIe SSD Cable Replacement, PCIe SSD Cable: passo 13, imagem 1 %32
    • Remove the two 2.6 mm T6 screws securing the PCIe SSD cable bracket.
  14. Mac mini Late 2014 PCIe SSD Cable Replacement: passo 14, imagem 1 %32 Mac mini Late 2014 PCIe SSD Cable Replacement: passo 14, imagem 2 %32
    • Remove the PCIe SSD cable bracket.
  15. Mac mini Late 2014 PCIe SSD Cable Replacement: passo 15, imagem 1 %32 Mac mini Late 2014 PCIe SSD Cable Replacement: passo 15, imagem 2 %32
    • Use the flat end of a spudger to lift the PCIe SSD connector straight up off of its connector on the logic board.
    • Be careful not to pry up on the socket itself.
  16. Mac mini Late 2014 PCIe SSD Cable Replacement: passo 16, imagem 1 %32 Mac mini Late 2014 PCIe SSD Cable Replacement: passo 16, imagem 2 %32
    • Slip the flat end of a spudger under the SSD cable to lift it off the adhesive holding it to the Mac mini.
  17. Mac mini Late 2014 PCIe SSD Cable Replacement: passo 17, imagem 1 %32
    • Remove the PCIe SSD cable from the Mac mini.
Conclusão
29 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
474.960 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.638 guias
8Comentários do guia
Where i can buy the PCIe SSD card?
melvin suarez - Responder
Where i can buy the PCIe SSD card, someone?
Claudio Vargas - Responder
I can supply these cables. Please reply to this thread.
Thomas Hall -
I found the ssd kit on eBay for $69ish. However, it doesn't include the ssd. Is it mPCI-e or is it an M.2 module?
Angelo - Responder
The SSD is neither, I believe. It is the same as the SSDs in the 2014 and up MacBook Pros. Pin format is 12+16
Daniel Abdulla -
Comentar
Visualizações:
Últimas 24 horas: 12
Últimos 7 dias: 81
Últimos 30 dias: 585
Ao todo: 63,010
