Ir para o conteúdo principal
Mac mini Late 2014 Antenna Plate Replacement
O que você precisa
  1. Mac mini Late 2014 Antenna Plate Replacement, Bottom Cover: passo 1, imagem 1 %32
    • The bottom cover is clipped onto three screw posts.
    • Pry near, but not right on the screw posts.
  2. Mac mini Late 2014 Antenna Plate Replacement: passo 2, imagem 1 %32 Mac mini Late 2014 Antenna Plate Replacement: passo 2, imagem 2 %32 Mac mini Late 2014 Antenna Plate Replacement: passo 2, imagem 3 %32
    • Use the plastic opening tool to pry the bottom cover up off of the Mac mini.
  3. Mac mini Late 2014 Antenna Plate Replacement: passo 3, imagem 1 %32 Mac mini Late 2014 Antenna Plate Replacement: passo 3, imagem 2 %32
    • Lift and remove the bottom cover.
  4. Mac mini Late 2014 Antenna Plate Replacement, Antenna Plate: passo 4, imagem 1 %32
    • Remove the following TR6 screws from the antenna plate:
    • Three 4.1 mm screws
    • Three 1.9 mm screws
  5. Mac mini Late 2014 Antenna Plate Replacement: passo 5, imagem 1 %32 Mac mini Late 2014 Antenna Plate Replacement: passo 5, imagem 2 %32
    • Do not completely remove the antenna plate; it is still connected to the Mac mini by an antenna cable.
    • With the I/O ports facing you, flip the antenna plate to the right to allow access to the antenna cable connector.
  6. Mac mini Late 2014 Antenna Plate Replacement: passo 6, imagem 1 %32
    • Remove the single 3.4 mm T6 screw and washer from the antenna cable.
    • Be careful not to lose the washer when removing the screw.
  7. Mac mini Late 2014 Antenna Plate Replacement: passo 7, imagem 1 %32 Mac mini Late 2014 Antenna Plate Replacement: passo 7, imagem 2 %32
    • Use the point of a spudger to lift the antenna connector straight up off its socket on the airport card.
  8. Mac mini Late 2014 Antenna Plate Replacement: passo 8, imagem 1 %32 Mac mini Late 2014 Antenna Plate Replacement: passo 8, imagem 2 %32
    • Carefully pull the antenna cable out from the gap between the power supply and case.
  9. Mac mini Late 2014 Antenna Plate Replacement: passo 9, imagem 1 %32
    • Remove the antenna plate from the Mac mini.
Conclusão
11 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
471.486 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.416 guias
Um comentário
Hello
I had really a problem with this instructions! The T6H Screw-Driver in the fixit-kit doesn’t fit in the holes of the 6 screws who hold the cover? Has Apple changes the screws of the macmini 2014, or has the T6H Screw-Driver has to much tolerance while produced!
I need to replace the HDD of the fusion drive! I will need to buy, HighEnd Tools to open my Cover ?!?
Gerard Dirks - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 31
Últimos 30 dias: 95
Duração total: 13,992
