Ir para o conteúdo principal
Mac mini Late 2014 AirPort Card Replacement
O que você precisa
  1. Mac mini Late 2014 AirPort Card Replacement, Bottom Cover: passo 1, imagem 1 %32
    • The bottom cover is clipped onto three screw posts.
    • Pry near, but not right on the screw posts.
  2. Mac mini Late 2014 AirPort Card Replacement: passo 2, imagem 1 %32 Mac mini Late 2014 AirPort Card Replacement: passo 2, imagem 2 %32 Mac mini Late 2014 AirPort Card Replacement: passo 2, imagem 3 %32
    • Use the plastic opening tool to pry the bottom cover up off of the Mac mini.
  3. Mac mini Late 2014 AirPort Card Replacement: passo 3, imagem 1 %32 Mac mini Late 2014 AirPort Card Replacement: passo 3, imagem 2 %32
    • Lift and remove the bottom cover.
  4. Mac mini Late 2014 AirPort Card Replacement, Antenna Plate: passo 4, imagem 1 %32
    • Remove the following TR6 screws from the antenna plate:
    • Three 4.1 mm screws
    • Three 1.9 mm screws
  5. Mac mini Late 2014 AirPort Card Replacement: passo 5, imagem 1 %32 Mac mini Late 2014 AirPort Card Replacement: passo 5, imagem 2 %32
    • Do not completely remove the antenna plate; it is still connected to the Mac mini by an antenna cable.
    • With the I/O ports facing you, flip the antenna plate to the right to allow access to the antenna cable connector.
  6. Mac mini Late 2014 AirPort Card Replacement: passo 6, imagem 1 %32
    • Remove the single 3.4 mm T6 screw and washer from the antenna cable.
    • Be careful not to lose the washer when removing the screw.
  7. Mac mini Late 2014 AirPort Card Replacement: passo 7, imagem 1 %32 Mac mini Late 2014 AirPort Card Replacement: passo 7, imagem 2 %32
    • Use the point of a spudger to lift the antenna connector straight up off its socket on the airport card.
  8. Mac mini Late 2014 AirPort Card Replacement: passo 8, imagem 1 %32 Mac mini Late 2014 AirPort Card Replacement: passo 8, imagem 2 %32
    • Carefully pull the antenna cable out from the gap between the power supply and case.
  9. Mac mini Late 2014 AirPort Card Replacement: passo 9, imagem 1 %32
    • Remove the antenna plate from the Mac mini.
  10. Mac mini Late 2014 AirPort Card Replacement, AirPort Card: passo 10, imagem 1 %32
  11. Mac mini Late 2014 AirPort Card Replacement: passo 11, imagem 1 %32 Mac mini Late 2014 AirPort Card Replacement: passo 11, imagem 2 %32 Mac mini Late 2014 AirPort Card Replacement: passo 11, imagem 3 %32
    • Use the point of a spudger to lift the antenna connectors up off their sockets.
  12. Mac mini Late 2014 AirPort Card Replacement: passo 12, imagem 1 %32
    • Remove the 2.7 mm T5 screw securing the AirPort card.
  13. Mac mini Late 2014 AirPort Card Replacement: passo 13, imagem 1 %32 Mac mini Late 2014 AirPort Card Replacement: passo 13, imagem 2 %32 Mac mini Late 2014 AirPort Card Replacement: passo 13, imagem 3 %32
    • Lift the free end of the AirPort card enough to grasp it by the edges.
  14. Mac mini Late 2014 AirPort Card Replacement: passo 14, imagem 1 %32 Mac mini Late 2014 AirPort Card Replacement: passo 14, imagem 2 %32
    • Pull the AirPort card straight out of its socket on the logic board and remove it from the Mac mini.
Conclusão
16 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
471.486 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.416 guias
4 comentários
Thanks. Took all of 20 minutes start to finish to upgrade my broken NIC.
Erik Westlund - Responder
Hmm, look like an M.2 interface, could an M.2 SSD be installed instead?
The Bionic Cyclist - Responder
Can confirm that the airport card for the 2015 Macbook Pro fits and functions perfectly as a replacement if you can’t find the mac mini one.
Sam Goddard - Responder
If something wrong with my bluetooth, is it also replace this logic board ?
Gordon Lee - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 42
Últimos 30 dias: 139
Duração total: 21,384
