Introdução
Use this guide to replace a faulty power supply.
O que você precisa
Place your thumbs in the depressions cut into the bottom cover.
Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
Remove the single 3.5 mm T6 Torx screw securing the cowling to the heat sink.
Remove the following screws securing the antenna plate to the mini:
Two 6.6 mm T8 Torx screws
Two 5.0 mm T8 Torx or 2.0 mm Hex screws (either screwdriver will work)
When putting back together:
Use the flat end of a spudger to pry the hard drive connector up from its socket on the logic board.
Ferramenta utilizada neste passo:Mac mini Logic Board Removal Tool$4.99
Insert the Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure it makes contact with the top side of outer case below the logic board before proceeding.
Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
Remove the Mac mini Logic Board Removal tool.
Pull the hard drive away from the front edge of the mini and remove it from the outer case.
Remove the 7.9 mm T6 Torx screw securing the power supply and hard drive tray to the outer case.
42 outras pessoas executaram este guia.
9Comentários do guia
Hello,
Can you please mention the part number of the powersupply module.
The instructions mention a T6, and T8 screwdrivers. The “Buy these tools” link to T6 and T8 security screwdrivers. There is no mention of the security version of these screwdrivers required. Can someone clarify?
For the late 2012 Apple Mac Mini, You do not need the security version of either the T6 nor the T8. However, I use the iFixit Pro Tech Tool Kit so mine are security torx. Either will work in this case. Goodluck!
(I’ve taken apart plenty of Apple products as well as 3 mac mini’s this week alone 2011, 2012, and 2012. They start using Safety Torx in 2014 to keep “clumsy customers” out. However that does not keep out the enthusiasts ;)
can the power supply be tested IN PLACE with volt amp meter? i can see the power supply pins after Step 3. many people i see searching for this want to know if their power supply is good or if failure is also the logic board. i would stop disassembly if logic board has failed. also would know if one had to order power supply and logic board immediately/at the same time. Thank you!
