Ir para o conteúdo principal
Mac mini Late 2012 Fan Replacement
O que você precisa
  1. Mac mini Late 2012 Fan Replacement, Bottom Cover: passo 1, imagem 1 %32 Mac mini Late 2012 Fan Replacement, Bottom Cover: passo 1, imagem 2 %32
    • Place your thumbs in the depressions cut into the bottom cover.
    • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
    • You do not need to apply much downward pressure while turning.
  2. Mac mini Late 2012 Fan Replacement: passo 2, imagem 1 %32
    • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
    • Remove the bottom cover and set it aside.
  3. Mac mini Late 2012 Fan Replacement, Fan: passo 3, imagem 1 %32
    • Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
  4. Mac mini Late 2012 Fan Replacement: passo 4, imagem 1 %32
    • Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
    • Removing the standoff screw is not necessary to remove the fan. You need only raise the fan enough to lift it off the standoff screw.
  5. Mac mini Late 2012 Fan Replacement: passo 5, imagem 1 %32 Mac mini Late 2012 Fan Replacement: passo 5, imagem 2 %32 Mac mini Late 2012 Fan Replacement: passo 5, imagem 3 %32
    • Lift the fan out of the mini for enough clearance to access its connector.
    • Grab all the wires at once and gently pull straight up to disconnect the fan from the logic board.
    • Do not pry at the socket, or you may rip it from the logic board.
    • Remove the fan.
Conclusão
33 outras pessoas executaram este guia.
Andrew Optimus Goldheart
Membro desde: 10/17/09
512.576 Reputação
Autoria de 407 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.828 guias
5Comentários do guia
If you shouls happen to rip the connector off the logic board, just replace the end of the connector wire with a usb plug and the connect it to the computer, Vola
Reginald O'Brikis - Responder
What or where does the spring go on the long torque screw?
on the logic board, or the inner bevels on the screw?
[deleted] - Responder
where does the mini get input cooling air?? I can see the output ports but don't see any path for inputting cool air.
thanks..
pvpeel - Responder
See that the cover has two parts, one of which is covering the WiFi antenna, whose base has holes? That's where the air is coming into the Mini from! All the fan is doing is easing/forcing the flow of air (through negative pressure) to go through the CPU heat sink and being exhausted (hot) through the vents on the back of the case.
As a matter of fact, when you remove the bottom cover, you'll normally see heaps of "dust bunnies" stuck in that side of the cover. Evidence that's where the air originally got into the case.
Bernie Hernandez -
The lengthy torque screw has no spring, therefore what's its purpose?
Angelica Rhodes - Responder
Comentar
Visualizações:
Últimas 24 horas: 34
Últimos 7 dias: 107
Últimos 30 dias: 326
Ao todo: 31,497
