Introdução
Remove the bottom cover to access components inside your Mac mini Mid 2011.
O que você precisa
Place your thumbs in the depressions cut into the bottom cover.
Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
19 outras pessoas executaram este guia.
