Ir para o conteúdo principal
Mac mini (PowerPC) Modem Replacement
O que você precisa
  1. Mac mini (PowerPC) Modem Replacement, Top Housing: passo 1, imagem 1 %32 Mac mini (PowerPC) Modem Replacement, Top Housing: passo 1, imagem 2 %32
    • Power down your Mac mini, disconnect all of the cables, and flip it over.
    • Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
    • The Jimmy should reach a stop about 3/8" down.
    Pergunte ao FixBot
  2. Mac mini (PowerPC) Modem Replacement: passo 2, imagem 1 %32 Mac mini (PowerPC) Modem Replacement: passo 2, imagem 2 %32 Mac mini (PowerPC) Modem Replacement: passo 2, imagem 3 %32
    • Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
    • There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing.
    Pergunte ao FixBot
  3. Mac mini (PowerPC) Modem Replacement: passo 3, imagem 1 %32 Mac mini (PowerPC) Modem Replacement: passo 3, imagem 2 %32
    • Once you have the first side free, rotate the Mac mini and start prying up on the front edge.
    • Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
    Pergunte ao FixBot
  4. Mac mini (PowerPC) Modem Replacement: passo 4, imagem 1 %32 Mac mini (PowerPC) Modem Replacement: passo 4, imagem 2 %32
    • You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
    Pergunte ao FixBot
  5. Mac mini (PowerPC) Modem Replacement: passo 5, imagem 1 %32 Mac mini (PowerPC) Modem Replacement: passo 5, imagem 2 %32
    • Keep working around the perimeter, freeing the clips along the final edge.
    Pergunte ao FixBot
  6. Mac mini (PowerPC) Modem Replacement: passo 6, imagem 1 %32 Mac mini (PowerPC) Modem Replacement: passo 6, imagem 2 %32
    • Flip the Mac mini back over and lift the top housing off of the lower housing.
    Pergunte ao FixBot
  7. Mac mini (PowerPC) Modem Replacement, Mass Storage Unit: passo 7, imagem 1 %32
    • If your mini does not have Airport installed, then skip this step.
    • Grasp the Airport antenna board and lift it off of the two plastic posts holding it in place. You may need to push back the black plastic tab jutting through the lower left corner of the board.
    Pergunte ao FixBot
  8. Mac mini (PowerPC) Modem Replacement: passo 8, imagem 1 %32
    • Remove the yellow tape securing the power button cable to the black plastic framework.
    Pergunte ao FixBot
  9. Mac mini (PowerPC) Modem Replacement: passo 9, imagem 1 %32
    • Remove the three black Phillips screws securing the plastic framework to the logic board and lower case.
    Pergunte ao FixBot
  10. Mac mini (PowerPC) Modem Replacement: passo 10, imagem 1 %32
    • Grasp the optical drive and mass storage unit in one hand and lift up enough so that you can see beneath it.
    Pergunte ao FixBot
  11. Mac mini (PowerPC) Modem Replacement: passo 11, imagem 1 %32
    • If your mini has neither an Airport card nor a Bluetooth board, you can simply lift the optical drive up and away. Otherwise, you need to disconnect the Airport and/or Bluetooth antenna cables first.
    • With your free hand, pull the Bluetooth cable up from Bluetooth board and unplug the Airport antenna cable from the right of the Airport card. Caution: both of these connections are very small. When re-assembling unit after repair, you may want to remove the two screws holding the airport card to the assembly and lift the card up and out to re-attach the cables.
    Pergunte ao FixBot
  12. Mac mini (PowerPC) Modem Replacement, Modem: passo 12, imagem 1 %32
    • Remove the two silver Phillips screws from the corners of the modem board.
    Pergunte ao FixBot
  13. Mac mini (PowerPC) Modem Replacement: passo 13, imagem 1 %32
    • Pull the modem up from its connector. If it sticks, just wiggle it back and forth a bit as you pull up.
    Pergunte ao FixBot
  14. Mac mini (PowerPC) Modem Replacement: passo 14, imagem 1 %32
    • Disconnect the RJ-11 cable from the back of the modem.
    Pergunte ao FixBot
Conclusão
Documentos anexados
iRobot
Membro desde: 09/24/09
1 Reputação
Autoria de 636 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 73
Ao todo: 6,027
