Ir para o conteúdo principal
Mac Pro Late 2013 RAM Replacement
  1. Mac Pro Late 2013 RAM Replacement, Outer Case: passo 1, imagem 1 %32 Mac Pro Late 2013 RAM Replacement, Outer Case: passo 1, imagem 2 %32
    • Slide the lock switch to the right, to the unlocked position.
  2. Mac Pro Late 2013 RAM Replacement: passo 2, imagem 1 %32 Mac Pro Late 2013 RAM Replacement: passo 2, imagem 2 %32 Mac Pro Late 2013 RAM Replacement: passo 2, imagem 3 %32
    • Lift the outer case straight up off the Mac Pro.
    • It may help to push down on the center of the fan while lifting the case up.
  3. Mac Pro Late 2013 RAM Replacement, RAM: passo 3, imagem 1 %32 Mac Pro Late 2013 RAM Replacement, RAM: passo 3, imagem 2 %32
    • Push the RAM release tab up.
    • The RAM slots will pivot outward to allow access to the RAM modules.
  4. Mac Pro Late 2013 RAM Replacement: passo 4, imagem 1 %32 Mac Pro Late 2013 RAM Replacement: passo 4, imagem 2 %32
    • Using two hands, pull the desired RAM module straight out of its slot.
    • To install new RAM modules, insert a new module into the appropriate slot, in the proper orientation. Press the RAM module into the slot until it is bottomed, then push the RAM tray back into the side of the Mac Pro.
Conclusão
40 outras pessoas executaram este guia.
Andrew Optimus Goldheart
Membro desde: 10/17/09
502.849 Reputação
Autoria de 407 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.817 guias
7 comentários
How much RAM can I add? I saw Apple offering 64G, but also saw OCW offering 128G - is the CPU/MMU able to really handle this?
Peter Reif - Responder
Using Intel ARK to compare here is what they can support!
For the 4 Core CPU Supports: 256 GB
For the 6 Core CPU Supports: 256 GB
For the 8 Core CPU Supports: 768 GB
For the 12 Core CPU Supports: 768 GB
See: http://ark.intel.com/compare/75779,75780...
sokoal117 -
I would add this to the previous reply : what can you do with 768GB RAM that your 64/128GB mac can't handle ?
Vincent Monteil -
If I am only installing two sticks of ram, does anyone have a suggestion for what slots I should install them into? Thanks for yet another great guide! -George
George Mihaly - Responder
I have the same question and can't find an answer online. Apple doesn't ship them with less than 3 populated.
JRBv3 -
Apple suggests that you insert them in order slots 1 2 3 4 they say (if i remember well) that once you have the mac ports in front of you, the 1st one is the one on the left.
Vincent Monteil -
Having a problem with my Mac Pro, got 2 modules of 16 each to upgrade, after removing the outer case y press the RAM TAB on Slots 1 and 2 and it’s kinda jammed, it won’t open, I tried pressing the TAB for slots 3 and 4 and opens perfectly. I tried everything without forcing to much the tab and the slots won't pivot outward. Has anybody this same issue> any suggestions of how to fix this? Thanks in advance
Daniel Cadena - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 15
Últimos 7 dias: 85
Últimos 30 dias: 358
Duração total: 32,264
