Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
Use this guide to remove the bottom of the outer case of your Mac Pro.
Peças
Nenhum componente especificado.
  1. Slide the lock switch to the right, to the unlocked position. Slide the lock switch to the right, to the unlocked position.
    • Slide the lock switch to the right, to the unlocked position.
  2. Lift the outer case straight up off the Mac Pro. It may help to push down on the center of the fan while lifting the case up. It may help to push down on the center of the fan while lifting the case up.
    • Lift the outer case straight up off the Mac Pro.
    • It may help to push down on the center of the fan while lifting the case up.
  3. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Flip the Mac Pro upside down, 180 degrees. Remove five 5.1 mm T10 Torx screws from the outer perimeter of the lower case. Remove five 5.1 mm T10 Torx screws from the outer perimeter of the lower case.
    • Flip the Mac Pro upside down, 180 degrees.
    • Remove five 5.1 mm T10 Torx screws from the outer perimeter of the lower case.
  5. Carefully lift the lower case up and remove it from the Mac Pro. Carefully lift the lower case up and remove it from the Mac Pro.
    • Carefully lift the lower case up and remove it from the Mac Pro.
Conclusão
3 outras pessoas concluíram este guia.
Andrew Optimus Goldheart
Membro desde: 17-10-2009
435.749 Reputação
411 Guias de autoria
equipe
iFixit Membro de iFixit
Community
107 Membros
10.268 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 19
Duração total: 1,750
