Ir para o conteúdo principal
Mac Pro Late 2013 Interconnect Board Replacement
O que você precisa
  1. Mac Pro Late 2013 Interconnect Board Replacement, Outer Case: passo 1, imagem 1 %32 Mac Pro Late 2013 Interconnect Board Replacement, Outer Case: passo 1, imagem 2 %32
    • Slide the lock switch to the right, to the unlocked position.
  2. Mac Pro Late 2013 Interconnect Board Replacement: passo 2, imagem 1 %32 Mac Pro Late 2013 Interconnect Board Replacement: passo 2, imagem 2 %32 Mac Pro Late 2013 Interconnect Board Replacement: passo 2, imagem 3 %32
    • Lift the outer case straight up off the Mac Pro.
    • It may help to push down on the center of the fan while lifting the case up.
  3. Mac Pro Late 2013 Interconnect Board Replacement, Fan Assembly: passo 3, imagem 1 %32 Mac Pro Late 2013 Interconnect Board Replacement, Fan Assembly: passo 3, imagem 2 %32 Mac Pro Late 2013 Interconnect Board Replacement, Fan Assembly: passo 3, imagem 3 %32
    • Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
    You don't have to remove the fan assy to get to the wifi board & card. It can be done with the fan assy still attached.
    Fat Mango - Responder
    Fat Mango is correct. That said. If you do pull the fan assembly note that the screws are all held in with blue Permatex and breaking them free takes a fair amount of effort. Getting a good set of Torx screwdrivers is a must.
    Jim WIlson - Responder
    Hey guys, what would happen if you only replace one card.. I have a D300 but the plan is to upgrade to D500 or D600. So If I can afford and install one instead of the pair would it increase something? or will it cause any conflict? I guess I don’t understand if I the Mac Pro has 2 D300 graphic cards that means each has 1GB? Same as If I would Install 1 D600 that would increase 3GB only? Thanks.
    marcotamayo - Responder
    D300 = 2GB each card. Very few apps uses two cards at the same time.
    Gio Cas -
    The (5) Screws are Apple part number 923-0713
    Steven Gier - Responder
  4. Mac Pro Late 2013 Interconnect Board Replacement: passo 4, imagem 1 %32 Mac Pro Late 2013 Interconnect Board Replacement: passo 4, imagem 2 %32
    • The fan assembly is attached to the rest of the computer by two cables on the IO board side.
    • Tilt the assembly up away from the IO board.
    • Do not try to remove the fan assembly yet, as it is still attached by two cables.
  5. Mac Pro Late 2013 Interconnect Board Replacement: passo 5, imagem 1 %32
    • While supporting the fan assembly with one hand, loosen the two T8 captive screws in the fan cable bracket.
    • These screws are captive in the Mac Pro. Do not try to remove these screws from your Mac Pro.
    On my Mac Pro (assembled mid-2017) these are T8 screws. In fact, there were no T7 screws anywhere in my machine.
    mark33 - Responder
    There was no bracket on top of the cable at all, so I got a bit confused, so I had to skip step 5 and 6.
    Rakesh - Responder
    On my machine, a TR7 worked to remove them due to the weird angle.
    Wilson Gaberino - Responder
  6. Mac Pro Late 2013 Interconnect Board Replacement: passo 6, imagem 1 %32
    • Use a pair of tweezers to pull the fan cable bracket away from the fan assembly.
  7. Mac Pro Late 2013 Interconnect Board Replacement: passo 7, imagem 1 %32 Mac Pro Late 2013 Interconnect Board Replacement: passo 7, imagem 2 %32
    • Use the flat end of a spudger to disconnect the fan assembly ribbon cable from the IO board.
  8. Mac Pro Late 2013 Interconnect Board Replacement: passo 8, imagem 1 %32
    • Disconnect the fan assembly antenna cable from the IO board.
    • Remove the fan assembly from the Mac Pro.
    You don't have to remove the fan assy to do the steps below. They can be done with the fan assy still attached.
  9. Mac Pro Late 2013 Interconnect Board Replacement, Lower Case: passo 9, imagem 1 %32 Mac Pro Late 2013 Interconnect Board Replacement, Lower Case: passo 9, imagem 2 %32 Mac Pro Late 2013 Interconnect Board Replacement, Lower Case: passo 9, imagem 3 %32
    • Flip the Mac Pro upside down, 180 degrees.
    • Remove five 5.1 mm T10 Torx screws from the outer perimeter of the lower case.
  10. Mac Pro Late 2013 Interconnect Board Replacement: passo 10, imagem 1 %32 Mac Pro Late 2013 Interconnect Board Replacement: passo 10, imagem 2 %32
    • Carefully lift the lower case up and remove it from the Mac Pro.
  11. Mac Pro Late 2013 Interconnect Board Replacement, Interconnect Board: passo 11, imagem 1 %32 Mac Pro Late 2013 Interconnect Board Replacement, Interconnect Board: passo 11, imagem 2 %32
    • Use the flat end of a spudger and a twisting motion to gently separate one side of the graphics card data connection.
  12. Mac Pro Late 2013 Interconnect Board Replacement: passo 12, imagem 1 %32 Mac Pro Late 2013 Interconnect Board Replacement: passo 12, imagem 2 %32 Mac Pro Late 2013 Interconnect Board Replacement: passo 12, imagem 3 %32
    • Gently separate the other side as well.
    • Flip the connector up and out of the way of the graphics card.
    • Repeat this procedure on the other graphics card.
  13. Mac Pro Late 2013 Interconnect Board Replacement: passo 13, imagem 1 %32
    • Remove the two 6.0 mm T8 Torx screws securing the interconnect board to the heat sink.
    These are actually 6.0mm T8 Torx Screws. 12/07/2016.
    Todd - Responder
    Ended up being T9 screws for me.
    Nathaniel Wilson - Responder
    mark33 - Responder
    These are T8 screws in my 2013 Mac Pro.
    Sangers - Responder
    T8 screws for me, i did and edit to this step
    Steve McGinn - Responder
    Ended up being T15 screws on my machine
    Spencer Curtis - Responder
  14. Mac Pro Late 2013 Interconnect Board Replacement: passo 14, imagem 1 %32 Mac Pro Late 2013 Interconnect Board Replacement: passo 14, imagem 2 %32 Mac Pro Late 2013 Interconnect Board Replacement: passo 14, imagem 3 %32
    • Gently walk the interconnect board straight up off the logic board's slot connection.
    • It is recommended to lift one side and then the other.
    • Do not try to remove the interconnect board from the Mac Pro yet, as it is still connected to the IO board.
  15. Mac Pro Late 2013 Interconnect Board Replacement: passo 15, imagem 1 %32 Mac Pro Late 2013 Interconnect Board Replacement: passo 15, imagem 2 %32
    • Flip the interconnect board up and over, exposing the IO board data cable.
    • Use the same sort of twisting and spreading motion with the flat end of a spudger to separate one side of the IO board data cable.
  16. Mac Pro Late 2013 Interconnect Board Replacement: passo 16, imagem 1 %32 Mac Pro Late 2013 Interconnect Board Replacement: passo 16, imagem 2 %32
    • Use the flat end of a spudger to separate the other side of the IO board data cable.
    • Bend the cable out of the way and remove the interconnect board from the Mac Pro.
Conclusão
7 outras pessoas executaram este guia.
Andrew Optimus Goldheart
Membro desde: 10/17/09
502.810 Reputação
Autoria de 407 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.817 guias
4 comentários
Why is it necessary to remove the fan?
johnsburdett - Responder
Hola necesito comprar esta placa de interconexión, donde puedo encontrarla? Saludos
RailabMac - Responder
excellent, thank you very much, I wanted to ask you where I can get this plate, what is the reference?
Asdrubal - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 45
Duração total: 5,475
