Ir para o conteúdo principal
Mac Pro Late 2013 Interconnect Board Replacement
O que você precisa
  1. Mac Pro Late 2013 Interconnect Board Replacement, Outer Case: passo 1, imagem 1 %32 Mac Pro Late 2013 Interconnect Board Replacement, Outer Case: passo 1, imagem 2 %32
    • Slide the lock switch to the right, to the unlocked position.
  2. Mac Pro Late 2013 Interconnect Board Replacement: passo 2, imagem 1 %32 Mac Pro Late 2013 Interconnect Board Replacement: passo 2, imagem 2 %32 Mac Pro Late 2013 Interconnect Board Replacement: passo 2, imagem 3 %32
    • Lift the outer case straight up off the Mac Pro.
    • It may help to push down on the center of the fan while lifting the case up.
  3. Mac Pro Late 2013 Interconnect Board Replacement, Fan Assembly: passo 3, imagem 1 %32 Mac Pro Late 2013 Interconnect Board Replacement, Fan Assembly: passo 3, imagem 2 %32 Mac Pro Late 2013 Interconnect Board Replacement, Fan Assembly: passo 3, imagem 3 %32
    • Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
  4. Mac Pro Late 2013 Interconnect Board Replacement: passo 4, imagem 1 %32 Mac Pro Late 2013 Interconnect Board Replacement: passo 4, imagem 2 %32
    • The fan assembly is attached to the rest of the computer by two cables on the IO board side.
    • Tilt the assembly up away from the IO board.
    • Do not try to remove the fan assembly yet, as it is still attached by two cables.
  5. Mac Pro Late 2013 Interconnect Board Replacement: passo 5, imagem 1 %32
    • While supporting the fan assembly with one hand, loosen the two T8 captive screws in the fan cable bracket.
    • These screws are captive in the Mac Pro. Do not try to remove these screws from your Mac Pro.
  6. Mac Pro Late 2013 Interconnect Board Replacement: passo 6, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use a pair of tweezers to pull the fan cable bracket away from the fan assembly.
  7. Mac Pro Late 2013 Interconnect Board Replacement: passo 7, imagem 1 %32 Mac Pro Late 2013 Interconnect Board Replacement: passo 7, imagem 2 %32
    • Use the flat end of a spudger to disconnect the fan assembly ribbon cable from the IO board.
  8. Mac Pro Late 2013 Interconnect Board Replacement: passo 8, imagem 1 %32
    • Disconnect the fan assembly antenna cable from the IO board.
    • Remove the fan assembly from the Mac Pro.
  9. Mac Pro Late 2013 Interconnect Board Replacement, Lower Case: passo 9, imagem 1 %32 Mac Pro Late 2013 Interconnect Board Replacement, Lower Case: passo 9, imagem 2 %32 Mac Pro Late 2013 Interconnect Board Replacement, Lower Case: passo 9, imagem 3 %32
    • Flip the Mac Pro upside down, 180 degrees.
    • Remove five 5.1 mm T10 Torx screws from the outer perimeter of the lower case.
  10. Mac Pro Late 2013 Interconnect Board Replacement: passo 10, imagem 1 %32 Mac Pro Late 2013 Interconnect Board Replacement: passo 10, imagem 2 %32
    • Carefully lift the lower case up and remove it from the Mac Pro.
  11. Mac Pro Late 2013 Interconnect Board Replacement, Interconnect Board: passo 11, imagem 1 %32 Mac Pro Late 2013 Interconnect Board Replacement, Interconnect Board: passo 11, imagem 2 %32
    • Use the flat end of a spudger and a twisting motion to gently separate one side of the graphics card data connection.
  12. Mac Pro Late 2013 Interconnect Board Replacement: passo 12, imagem 1 %32 Mac Pro Late 2013 Interconnect Board Replacement: passo 12, imagem 2 %32 Mac Pro Late 2013 Interconnect Board Replacement: passo 12, imagem 3 %32
    • Gently separate the other side as well.
    • Flip the connector up and out of the way of the graphics card.
    • Repeat this procedure on the other graphics card.
  13. Mac Pro Late 2013 Interconnect Board Replacement: passo 13, imagem 1 %32
    • Remove the two 6.0 mm T8 Torx screws securing the interconnect board to the heat sink.
  14. Mac Pro Late 2013 Interconnect Board Replacement: passo 14, imagem 1 %32 Mac Pro Late 2013 Interconnect Board Replacement: passo 14, imagem 2 %32 Mac Pro Late 2013 Interconnect Board Replacement: passo 14, imagem 3 %32
    • Gently walk the interconnect board straight up off the logic board's slot connection.
    • It is recommended to lift one side and then the other.
    • Do not try to remove the interconnect board from the Mac Pro yet, as it is still connected to the IO board.
  15. Mac Pro Late 2013 Interconnect Board Replacement: passo 15, imagem 1 %32 Mac Pro Late 2013 Interconnect Board Replacement: passo 15, imagem 2 %32
    • Flip the interconnect board up and over, exposing the IO board data cable.
    • Use the same sort of twisting and spreading motion with the flat end of a spudger to separate one side of the IO board data cable.
  16. Mac Pro Late 2013 Interconnect Board Replacement: passo 16, imagem 1 %32 Mac Pro Late 2013 Interconnect Board Replacement: passo 16, imagem 2 %32
    • Use the flat end of a spudger to separate the other side of the IO board data cable.
    • Bend the cable out of the way and remove the interconnect board from the Mac Pro.
Conclusão
7 outras pessoas executaram este guia.
Andrew Optimus Goldheart
Membro desde: 10/17/09
504.362 Reputação
Autoria de 407 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 140
Autoria de 18.058 guias
4 comentários
Why is it necessary to remove the fan?
johnsburdett - Responder
Hola necesito comprar esta placa de interconexión, donde puedo encontrarla? Saludos
RailabMac - Responder
excellent, thank you very much, I wanted to ask you where I can get this plate, what is the reference?
Asdrubal - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 44
Duração total: 5,612
