O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
While supporting the fan assembly with one hand, loosen the two T8 captive screws in the fan cable bracket.
Ferramenta utilizada nesse passo:Tweezers$4.99-
Use a pair of tweezers to pull the fan cable bracket away from the fan assembly.
Use the flat end of a spudger to disconnect the fan assembly ribbon cable from the IO board.
Disconnect the fan assembly antenna cable from the IO board.
Remove the fan assembly from the Mac Pro.
