Ir para o conteúdo principal
Mac Pro Late 2013 AirPort Card Replacement
O que você precisa
  1. Mac Pro Late 2013 AirPort Card Replacement, Outer Case: passo 1, imagem 1 %32 Mac Pro Late 2013 AirPort Card Replacement, Outer Case: passo 1, imagem 2 %32
    • Slide the lock switch to the right, to the unlocked position.
  2. Mac Pro Late 2013 AirPort Card Replacement: passo 2, imagem 1 %32 Mac Pro Late 2013 AirPort Card Replacement: passo 2, imagem 2 %32 Mac Pro Late 2013 AirPort Card Replacement: passo 2, imagem 3 %32
    • Lift the outer case straight up off the Mac Pro.
    • It may help to push down on the center of the fan while lifting the case up.
  3. Mac Pro Late 2013 AirPort Card Replacement, Fan Assembly: passo 3, imagem 1 %32 Mac Pro Late 2013 AirPort Card Replacement, Fan Assembly: passo 3, imagem 2 %32 Mac Pro Late 2013 AirPort Card Replacement, Fan Assembly: passo 3, imagem 3 %32
    • Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
  4. Mac Pro Late 2013 AirPort Card Replacement: passo 4, imagem 1 %32 Mac Pro Late 2013 AirPort Card Replacement: passo 4, imagem 2 %32
    • The fan assembly is attached to the rest of the computer by two cables on the IO board side.
    • Tilt the assembly up away from the IO board.
    • Do not try to remove the fan assembly yet, as it is still attached by two cables.
  5. Mac Pro Late 2013 AirPort Card Replacement: passo 5, imagem 1 %32
    • While supporting the fan assembly with one hand, loosen the two T8 captive screws in the fan cable bracket.
    • These screws are captive in the Mac Pro. Do not try to remove these screws from your Mac Pro.
  6. Mac Pro Late 2013 AirPort Card Replacement: passo 6, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use a pair of tweezers to pull the fan cable bracket away from the fan assembly.
  7. Mac Pro Late 2013 AirPort Card Replacement: passo 7, imagem 1 %32 Mac Pro Late 2013 AirPort Card Replacement: passo 7, imagem 2 %32
    • Use the flat end of a spudger to disconnect the fan assembly ribbon cable from the IO board.
  8. Mac Pro Late 2013 AirPort Card Replacement: passo 8, imagem 1 %32
    • Disconnect the fan assembly antenna cable from the IO board.
    • Remove the fan assembly from the Mac Pro.
  9. Mac Pro Late 2013 AirPort Card Replacement, Fan Assembly Lid: passo 9, imagem 1 %32 Mac Pro Late 2013 AirPort Card Replacement, Fan Assembly Lid: passo 9, imagem 2 %32 Mac Pro Late 2013 AirPort Card Replacement, Fan Assembly Lid: passo 9, imagem 3 %32
    • Use the flat end of a spudger to pry the fan assembly lid up off the fan assembly.
    • Remove the fan assembly lid.
  10. Mac Pro Late 2013 AirPort Card Replacement, AirPort Board: passo 10, imagem 1 %32
    • Remove the three 3.7 mm T4 screws securing the metal cover to the AirPort board bay.
  11. Mac Pro Late 2013 AirPort Card Replacement: passo 11, imagem 1 %32
    • Lift and remove the metal cover from the AirPort board bay.
  12. Mac Pro Late 2013 AirPort Card Replacement: passo 12, imagem 1 %32 Mac Pro Late 2013 AirPort Card Replacement: passo 12, imagem 2 %32 Mac Pro Late 2013 AirPort Card Replacement: passo 12, imagem 3 %32
    • Use the tip of a spudger to flip the ZIF retaining tab on the fan assembly ribbon cable connector.
    • Remove the fan assembly ribbon cable from its ZIF socket.
  13. Mac Pro Late 2013 AirPort Card Replacement: passo 13, imagem 1 %32 Mac Pro Late 2013 AirPort Card Replacement: passo 13, imagem 2 %32 Mac Pro Late 2013 AirPort Card Replacement: passo 13, imagem 3 %32
    • Use the tip of a spudger to flip the ZIF retaining tab on the fan ribbon cable.
    • Disconnect the fan ribbon cable.
  14. Mac Pro Late 2013 AirPort Card Replacement, AirPort Card: passo 14, imagem 1 %32 Mac Pro Late 2013 AirPort Card Replacement, AirPort Card: passo 14, imagem 2 %32 Mac Pro Late 2013 AirPort Card Replacement, AirPort Card: passo 14, imagem 3 %32
    • Use the tip of a spudger to disconnect the four AirPort antenna cables from the AirPort card.
  15. Mac Pro Late 2013 AirPort Card Replacement: passo 15, imagem 1 %32
    • Remove three 3.7 mm T4 screws securing the AirPort board to the fan assembly.
  16. Mac Pro Late 2013 AirPort Card Replacement: passo 16, imagem 1 %32
    • Remove the AirPort board and card from the fan assembly.
  17. Mac Pro Late 2013 AirPort Card Replacement: passo 17, imagem 1 %32
    • Remove the two 3.7 mm T4 Torx screws securing the AirPort card to the AirPort board.
  18. Mac Pro Late 2013 AirPort Card Replacement: passo 18, imagem 1 %32 Mac Pro Late 2013 AirPort Card Replacement: passo 18, imagem 2 %32
    • Slide the AirPort card out of its socket in the AirPort board.
Conclusão
3 outras pessoas executaram este guia.
Andrew Optimus Goldheart
Membro desde: 10/17/09
512.205 Reputação
Autoria de 407 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.603 guias
4Comentários do guia
Is there a way to replace the Mac Pro Airport card with a more recent one, like when you insert a recent one in an old macbook pro to get new features such as "unlock my mac with my apple watch" ? This is an interesting question that remains unanswered (until now ?)
Vincent Monteil - Responder
You show how to replace it but I can’t buy it from ifixit….why?
Sanong - Responder
Why not start at step 9 and leave the lid attached?
dillonrw - Responder
I wondered the exact same thing. I can see zero reason to remove the fan assembly from the top of the machine just to replace the wifi card. The only reason I can see for doing it would be if you drop a screw it’s at least easy to get to, because everything is separate from the core unit.
David Orriss Jr -
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 62
Últimos 30 dias: 257
Ao todo: 12,425
