Ir para o conteúdo principal
Mac Pro Late 2013 AirPort Antenna Array Replacement
O que você precisa
  1. Mac Pro Late 2013 AirPort Antenna Array Replacement, Outer Case: passo 1, imagem 1 %32 Mac Pro Late 2013 AirPort Antenna Array Replacement, Outer Case: passo 1, imagem 2 %32
    • Slide the lock switch to the right, to the unlocked position.
  2. Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 2, imagem 1 %32 Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 2, imagem 2 %32 Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 2, imagem 3 %32
    • Lift the outer case straight up off the Mac Pro.
    • It may help to push down on the center of the fan while lifting the case up.
  3. Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly: passo 3, imagem 1 %32 Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly: passo 3, imagem 2 %32 Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly: passo 3, imagem 3 %32
    • Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
  4. Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 4, imagem 1 %32 Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 4, imagem 2 %32
    • The fan assembly is attached to the rest of the computer by two cables on the IO board side.
    • Tilt the assembly up away from the IO board.
    • Do not try to remove the fan assembly yet, as it is still attached by two cables.
  5. Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 5, imagem 1 %32
    • While supporting the fan assembly with one hand, loosen the two T8 captive screws in the fan cable bracket.
    • These screws are captive in the Mac Pro. Do not try to remove these screws from your Mac Pro.
  6. Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 6, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use a pair of tweezers to pull the fan cable bracket away from the fan assembly.
  7. Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 7, imagem 1 %32 Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 7, imagem 2 %32
    • Use the flat end of a spudger to disconnect the fan assembly ribbon cable from the IO board.
  8. Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 8, imagem 1 %32
    • Disconnect the fan assembly antenna cable from the IO board.
    • Remove the fan assembly from the Mac Pro.
  9. Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly Lid: passo 9, imagem 1 %32 Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly Lid: passo 9, imagem 2 %32 Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly Lid: passo 9, imagem 3 %32
    • Use the flat end of a spudger to pry the fan assembly lid up off the fan assembly.
    • Remove the fan assembly lid.
  10. Mac Pro Late 2013 AirPort Antenna Array Replacement, AirPort Board: passo 10, imagem 1 %32
    • Remove the three 3.7 mm T4 screws securing the metal cover to the AirPort board bay.
  11. Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 11, imagem 1 %32
    • Lift and remove the metal cover from the AirPort board bay.
  12. Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 12, imagem 1 %32 Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 12, imagem 2 %32 Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 12, imagem 3 %32
    • Use the tip of a spudger to flip the ZIF retaining tab on the fan assembly ribbon cable connector.
    • Remove the fan assembly ribbon cable from its ZIF socket.
  13. Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 13, imagem 1 %32 Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 13, imagem 2 %32 Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 13, imagem 3 %32
    • Use the tip of a spudger to flip the ZIF retaining tab on the fan ribbon cable.
    • Disconnect the fan ribbon cable.
  14. Mac Pro Late 2013 AirPort Antenna Array Replacement, AirPort Antenna Array: passo 14, imagem 1 %32
    • Remove the three 3.7 mm T4 screws securing the antenna array to the fan assembly.
  15. Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 15, imagem 1 %32
    • Remove the AirPort antenna array.
Conclusão
3 outras pessoas executaram este guia.
Andrew Optimus Goldheart
Membro desde: 10/17/09
504.362 Reputação
Autoria de 407 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 140
Autoria de 18.058 guias
2 comentários
having macpro 2013 bluetooth on issue, where is the bluetooth module locate?
Sanong - Responder
is bluetooth module part of (inside) airport board?
Sanong - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 44
Duração total: 5,402
