Ir para o conteúdo principal
Peças
Nenhum componente especificado.
  1. Begin by pulling up on the lever located at the back of the computer to remove the side panel.
    • Begin by pulling up on the lever located at the back of the computer to remove the side panel.
  2. Gently pull outward on each of the four hard drive trays to remove them.
    • Gently pull outward on each of the four hard drive trays to remove them.
  3. Remove the two 10mm PH #1 screws holding in the PCIe fan.
    • Remove the two 10mm PH #1 screws holding in the PCIe fan.
  4. Gently pull the fan outward to remove.
    • Gently pull the fan outward to remove.
Conclusão
2 outras pessoas concluíram este guia.
Andrew Damiani
Membro desde: 30/07/2017
164 Reputação
Autoria de 1 guia
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 3,261
