Ir para o conteúdo principal
Mac Pro First Generation Optical Drive Replacement
O que você precisa
  1. Mac Pro First Generation Optical Drive Replacement, Optical Drive: passo 1, imagem 1 %32
    • Lift the lever to unlock the case
  2. Mac Pro First Generation Optical Drive Replacement: passo 2, imagem 1 %32
    • Remove the side panel of the Mac Pro
  3. Mac Pro First Generation Optical Drive Replacement: passo 3, imagem 1 %32 Mac Pro First Generation Optical Drive Replacement: passo 3, imagem 2 %32 Mac Pro First Generation Optical Drive Replacement: passo 3, imagem 3 %32
    • Firmly grasp the handles of the shown compartment and pull out firmly to remove the optical drive bay.
  4. Mac Pro First Generation Optical Drive Replacement: passo 4, imagem 1 %32
    • Firmly hold each of the two connectors and pull them out of their respective sockets.
  5. Mac Pro First Generation Optical Drive Replacement: passo 5, imagem 1 %32 Mac Pro First Generation Optical Drive Replacement: passo 5, imagem 2 %32
    • Unscrew the shown two 6-32 type screws on each side of the optical drive.
  6. Mac Pro First Generation Optical Drive Replacement: passo 6, imagem 1 %32 Mac Pro First Generation Optical Drive Replacement: passo 6, imagem 2 %32
    • Firmly grasp the optical drive and pull it out of its enclosure.
    To make the pull easier without pluming the whole body over- pull with your fingers and brace your thumbs on the tower chassis above - worked for me.
    Nick Rogers - Responder
    Correction, for pluming read pulling!
Conclusão
21 outras pessoas executaram este guia.
Derek Chan
Membro desde: 10/13/14
1.416 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 6-24, Maness Fall 2014 Membro de Cal Poly, Team 6-24, Maness Fall 2014
CPSU-MANESS-F14S6G24
Membros da 4
Autoria de 13 guias
10 comentários
Thanks! It had been a long time since I'd been inside my towers! Easy-peasy!
Janie Wilson-Cook - Responder
I am having problems with the new optical drive not being able to eject and close without my help. Any thoughts?
footeking - Responder
Did you take off the front of the tray?
nbeijer -
Awesome!!! Worked like a charm! Drive is totally busted. Do you have a link or a suggestion for an optical drive for a late 2009 Mac pro? Thanks either way!
Jay Haser - Responder
The unit holding the optical drive will NOT pull out at all and I and really pulling on it and wiggling it. All other videos show it popping out with little force. What am I doing wrong?
pipevape - Responder
I am having the same problem did you figure out what was wrong?
Tony Bounsall -
Probably just stuck. I’ve had mine out several times before, but the lever at the back of the case must be open. When it’s closed, it locks it in.
Aquenon -
I am having the same problem . I raised the lever handle no problem---Is there another interlock ?
Chuck Hendricks -
I am having the same problem. The lever arm comes up and stays up no Problem. Is there another interlock to release the optical drive door ?
vamochuck@gmail.com
Chuck Hendricks -
I am having the same problem. Any solution ?
vamochuck@gmail.com
Chuck Hendricks -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 56
Duração total: 16,713
